      1、急停批量复位:
IF Emergency_Stop THEN   ZRST(M5, M23);   ZRST(M25, M79);   B_Pump_SDKZ:=FALSE;   DC_Pump:=FALSE;END_IF
        2、手动开关电动阀:
IF   NOT M10 THEN// 电动阀1手动触摸屏开阀控制,到位停止 M1:Valve1_SD_OpenIF Valve1_SD_Open and not Valve1_Opened THEN                       M81 := FALSE;                       IF NOT Valve1_Close THEN  M80 := TRUE;END_IF            ELSEIF Valve1_Opened THEN  Valve1_SD_Open := FALSE;            END_IF
// 电动阀1手动触摸屏关阀控制,到位停止 M2:Valve1_SD_Close            IF Valve1_SD_Close AND NOT Valve1_Closed THENM80 := FALSE;                       IF NOT Valve1_Open THEN  M81 := TRUE;END_IF            ELSIF Valve1_Closed THENValve1_SD_Close:=FALSE;            END_IF
// 电动阀2手动触摸屏开阀控制,到位停止 M3:Valve2_SD_Open            IF Valve2_SD_Open AND NOT valve2_Opened THEN                       M83 := FALSE;                       IF NOT Valve2_Close THEN                           M82:= TRUE;END_IF            ELSIF Valve2_Opened THEN  Valve2_SD_Open:=FALSE;            END_IF
// 电动阀2手动触摸屏关阀控制,到位停止 M4:Valve2_SD_Close            IF Valve2_SD_Close AND NOT Valve2_Closed THEN                        M82 := FALSE;                        IF NOT Valve2_Open THEN                   M83:=TRUE;               END_IF            ELSIF Valve2_Closed THEN                Valve2_SD_Close:=FALSE;END_IF
ELSE;END_IF
      3、调用子程序
SBR_001();SBR_002();SBR_006();
      4、使用接通延时定时器
TONR(IN := X12,PT := K1000,R := ,Q => M78,ET => D100 );
      X12接通,延时1S(K1000),M78吸合,D100显示定时器实时值,类型为DINT。
