带电操作是先接零线?还是先接火线?带电作业时先断火线,后断零线。接线时相反,先接零线后接火线。有用电器的情况下,不管先接火线还是零线都要产生电弧的,用电器的功率越大产生的电弧越大,一般不带负载带电作业,小负 ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.6318130168200815&vid=a1334h6j3py&width=452&height=254.25&autoplay=false&allowFullScreen=tru ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.8128948679141043&vid=c1327a0ijj9&width=452&height=254.25&autoplay=false&allowFullScreen=tru ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.28914997733755043&vid=y1327q7ny20&width=460&height=258.75&autoplay=false&allowFullScreen=tr ...
维修资料书。手机轻松学。如字体小,可点击图片放大看。 免责声明:如果侵犯了您的权益,请联系站长,我们会及时删除侵权内容,谢谢合作!
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.5915756925516825&vid=w13396nyhwm&width=657&height=369.5625&autoplay=false&allowFullScreen=t ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.1942472486049276&vid=j0395jmqr5o&width=657&height=492.75&autoplay=false&allowFullScreen=tru ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.9565906922388345&vid=l1327rx9hwr&width=452&height=254.25&autoplay=false&allowFullScreen=tru ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.1603886666060118&vid=x13277e81mp&width=460&height=345&autoplay=false&allowFullScreen=true&c ...
一、故障代码汇总表二、常见故障的快速判断家用空调器的常见故障,无论是窗式空调器还是分体式空调器,其直观反映大多是不制冷(热)或制冷/制热量不足;机器不能正常运转,运转后立即自动停机或是运行中突然自动 ...
美的商用空调控制器因市场需要而研发了很多种型号。这里我们将对原理性的东西做重点介绍。1. 型号说明2. 物料编码说明一、 KJR-01B(-C)/dP KJR-01B(-C),dP(带-C指单冷)又称定频线控器,这款线控器 ...
美的MB-FS40J型全智能电饭煲采用单片机SH79F081M控制。该型号电饭煲功能齐全,具有预约功能。该系列电饭煲说明书仅附带了简单的电气接线示意图,现在修理该型号电饭煲时测绘了电气原理图,如图1、2所示。一、简述 ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.1762606834308501&vid=g00257px2ub&width=452&height=339&autoplay=false&allowFullScreen=true&c ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.6847447724914273&vid=o1326i2izj8&width=460&height=258.75&autoplay=false&allowFullScreen=tru ...
维修工具书。手机轻松查。如字体小,可点击图片放大看。 免责声明:如果侵犯了您的权益,请联系站长,我们会及时删除侵权内容,谢谢合作!
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.9370081716726579&vid=p1335zzim1p&width=452&height=254.25&autoplay=false&allowFullScreen=tru ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.5060653488338341&vid=n05620ke322&width=460&height=258.75&autoplay=false&allowFullScreen=tru ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.5551077528729217&vid=f1331sl75hp&width=460&height=258.75&autoplay=false&allowFullScreen=tru ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.30112440285874265&vid=m1326gp9h6l&width=452&height=254.25&autoplay=false&allowFullScreen=tr ...
今天要给大家种草了我森森滴知道,当你们点开这篇文章的时候心里对小编一定是又爱又恨的爱我是因为我又帮你们打开了一扇新世界的大门恨我是因为你们的钱包要减肥了先来看看强大的视频://v.qq.com/txp/iframe/playe ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.15038854330084006&vid=a1325hs6t5l&width=452&height=254.25&autoplay=false&allowFullScreen=tr ...
电气故障检修的三步骤1、观察和调查故障现象电气故障现象是多种多样的。例如,同一类故障可能有不同的故障现象,不同类故障可能有同种故障现象,这种故障现象的同一性和多样性,给查找故障带来复杂性。但是,故障现 ...
在修理红外遥控电器时,如果是遥控部分出现故障,首先要确定发射器有无信号发出,尤其是那些没有指示灯的发射器,人眼又看不出红外线,因此有个红外检测器很有必要。该袖珍红外检测器电路如图1所示。没有红外信号时 ...
实例1、机型:L42F1590B 机芯:RT49故障现象:不开机。 分析与检修:开机后灯不亮。测3.3V正常,但是测24V有抖动,说明故障在电源板。电源板型号为PBE039。重点检测稳压电路,代换U2(P621)、U3(TL43 ...
例1、长虹LT42710FHD人脸部偏红色 开机,无论怎么试调亮度、对比度、色度、白平衡,图像脸部始终偏红色,有种油光发亮的感觉,菜单上的字在行末可看到有半边灰白色,有点类似于CRT中图像拖尾的感觉。怀 ...
《风雨红尘》//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.840324729683379&vid=o0505xgm01h&width=436&height=245.25&autoplay=false&allowFul ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.8653637726431642&vid=i1327c07c6v&width=452&height=254.25&autoplay=false&allowFullScreen=tru ...
在炎热的夏季,机场停机坪上的地面温度可达40度(摄氏度)以上。飞机依靠空调系统保持适当的客舱温度,使之保持在舒适的24度左右。以波音B777-200LR飞机为例,其客舱空间大约为520m?,相当于一间185平米左右的房间 ...
答案在最后,看有没有得满分的:一、填空题1. 普通双桶洗衣机的洗涤电动机通常有4种功率规: 、 、 、 。2. 滚筒式洗衣机的特点有: 、 ...
贴片LED灯珠规格通常以其长度和宽度来组合命名,比如5730灯珠,表示长度是5.7mm,宽度是3.0mm。用作LED背光的灯珠规格一般有7020、4014、3030等。值得一提的是,用作背光的灯珠除规格不同外,单个灯珠的工作电压有3 ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.633074536362721&vid=r1337sxmrlf&width=452&height=339&autoplay=false&allowFullScreen=true&ch ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.18831100165202186&vid=m0541sw4xc5&width=452&height=254.25&autoplay=false&allowFullScreen=tr ...
1、安全事项R-410A比R-22冷媒的压力要高大约1.6倍左右,所以,在施工与售后服务的过程中一旦发生错误的操作,将有可能发生重大的事故。在安装R-410A冷媒的空调时,请使用R-410A专用工具以及材料,注意安全操作。1.1 ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.19613318079915676&vid=f13250q8e2f&width=452&height=254.25&autoplay=false&allowFullScreen=tr ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.018453084001700537&vid=s1337yjlo1c&width=452&height=254.25&autoplay=false&allowFullScreen=t ...
(一)日立多联中央空调故障代码表(二)日立家用IVXmini中央空调故障代码表(三)日立分体式空调故障代码表一、柜机KF(Rd)?46、50、65、70LW 故障分析:(故障显示:1?18、2 ?19灯常亮,定时、温度灯闪)1. 12?2 ...
一、如何理解“热泵”?举个简单的例子,汽车耗几升汽油就可以把几吨货物从一个地方运到另一个地方,热泵机组可从自然界中吸收热量经过热泵的“搬运”(电力做功驱动热泵),获得可用于生产、生活的热能。二、热泵 ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.5911716732035863&vid=k13266n8k1u&width=452&height=339&autoplay=false&allowFullScreen=true&c ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.3331582134118336&vid=f0534j099vg&width=436&height=245.25&autoplay=false&allowFullScreen=tru ...
维修工具书。手机轻松查。如字体小,可点击图片放大看。全书完。 免责声明:如果侵犯了您的权益,请联系站长,我们会及时删除侵权内容,谢谢合作! ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.6336917502924946&vid=b13251hf0z5&width=452&height=254.25&autoplay=false&allowFullScreen=tru ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.06933958245515659&vid=f1323tldmh2&width=460&height=258.75&autoplay=false&allowFullScreen=tr ...
断路器跳闸, 无外乎以下五种原因,结合实际情况判断,即可了解、发现、解决故障。注意:在检修电路时,一定要保证上一级断路器处于断开状态。原因一:过载过载保护,是断路器的一项基本功能,任何断路器,都有这项 ...
普通空调加氟方法视频。空调加氟方法与技巧。冰箱加氟视频指导教程。空调的常用制冷剂R22与R410A分析。如何根据观察阀门结霜结露情况判断空调制冷剂是否正常。 免责声明:如果侵犯了您的权益,请联系站长,我们会及 ...
国务院安全生产委员会在国务院领导下,安排部署2018年度安全生产月工作:今年6月以“生命至上 安全发展”为主题开展2018安全生产月;6月1日,国务院安委会在江苏省江阴市举行2018安全生产月启动式;6月16日,国务院 ...
很多新入电气行业的朋友,对高压和低压的概念不是很清楚,哪怕是做了很多年电气的朋友,可能平时只接触电气大家族里面的一部分,对高低压专业方面的知识接触也不多,所以,可能在这一块的知识并不是很系统。今天在 ...
//v.qq.com/txp/iframe/player.html?origin=https%3A%2F%2Fmp.weixin.qq.com&containerId=js_tx_video_container_0.8465757899318781&vid=p0565f2634w&width=452&height=339&autoplay=false&allowFullScreen=true&c ...
一、空调化霜进入条件1、当进入制热模式或者除霜模式大概5分钟后,根据外机盘管温度和室内温度的最大差值,来判断,判断时间为3分钟。 2、当内盘管温度和室内温度的差值减小5度以上并且持续3分钟以上, 3、保证压 ...
第一步:当然是下载纯净系统,下面以win7系统为例子,贴出系统下载地址,如果不知道自己电脑是多少位的,大家打开运行窗口(Win+R),输入cmd , 然后敲入systeminfo 点击回车会在下图中看到电脑信息,然后依照版本 ...
