点击上方蓝字关注我们
微信公众号:OpenCV学堂
关注获取更多计算机视觉与深度学习知识
软件版本与依赖
下载与安装Pycharm专业版下载与安装Python3.6.5VS2015专业版(可选)
安装OpenCV与PyQt5
安装OpenCV4.4
pip install opencv-python
安装PyQt5
pip install pyqt5pip install PyQt5-tools
配置Pycharm开发环境
打开Pycharm,新建一个项目
选择到你安装的python3.6.5对应的解释器,这步很关键!然后填好项目名称,然后点击【create】按钮即可。
然后从【File】->【Settings】中选择Extenal Tools,如下图所示:
点击添加,QT Designer,PyUIC两个工具,它们的设置如下图:
C:\Users\Administrator\AppData\Local\Programs\Python\Python36\Lib\site-packages\qt5_applications\Qt\bin\designer.exe
-m PyQt5.uic.pyuic $FileName$ -o $FileNameWithoutExtension$.py
设置好之后,点击确认,从最上部【Tools】->【Extenal Tools】中选择QT Designer 打开如下所示:
PyQy5快速开发测试
就可以直接通过pycharm调用QT Designer来设计界面了!我设计的界面如下:
然后保存文件为test.ui
右键test.ui 选择转换为python代码,得到的代码如下:
#  -*-  coding:  utf-8  -*-
#  Form  implementation  generated  from  reading  ui  file  'test.ui'
#  Created  by:  PyQt5  UI  code  generator  5.15.1
#  WARNING:  Any  manual  changes  made  to  this  file  will  be  lost  when  pyuic5  is
#  run  again.    Do  not  edit  this  file  unless  you  know  what  you  are  doing.
import  sys
from  PyQt5  import  QtCore,  QtGui,  QtWidgets
class  Ui_MainWindow(object):
        def  setupUi(self,  MainWindow):
                MainWindow.setObjectName("MainWindow")
                MainWindow.resize(800,  600)
                self.centralwidget  =  QtWidgets.QWidget(MainWindow)
                self.centralwidget.setObjectName("centralwidget")
                self.label  =  QtWidgets.QLabel(self.centralwidget)
                self.label.setGeometry(QtCore.QRect(80,  110,  591,  371))
                self.label.setObjectName("label")
                self.label_2  =  QtWidgets.QLabel(self.centralwidget)
                self.label_2.setGeometry(QtCore.QRect(80,  20,  91,  41))
                self.label_2.setObjectName("label_2")
                MainWindow.setCentralWidget(self.centralwidget)
                self.menubar  =  QtWidgets.QMenuBar(MainWindow)
                self.menubar.setGeometry(QtCore.QRect(0,  0,  800,  25))
                self.menubar.setObjectName("menubar")
                MainWindow.setMenuBar(self.menubar)
                self.statusbar  =  QtWidgets.QStatusBar(MainWindow)
                self.statusbar.setObjectName("statusbar")
                MainWindow.setStatusBar(self.statusbar)
                self.retranslateUi(MainWindow)
                QtCore.QMetaObject.connectSlotsByName(MainWindow)
        def  retranslateUi(self,  MainWindow):
                _translate  =  QtCore.QCoreApplication.translate
                MainWindow.setWindowTitle(_translate("MainWindow",  "OpenCV学堂-QT+OpenCV  Python版本"))
                self.label.setText(_translate("MainWindow",  "TextLabel"))
                self.label_2.setText(_translate("MainWindow",  "OpenCV学堂"))
添加一段调用代码,
if  __name__  ==  "__main__":
        app  =  QtWidgets.QApplication(sys.argv)
        MainWindow  =  QtWidgets.QMainWindow()
        ui  =  Ui_MainWindow()
        ui.setupUi(MainWindow)
        image  =  QtGui.QPixmap('D:/images/lena.jpg')
        ui.label.setPixmap(image)
        ui.label.setAlignment(QtCore.Qt.AlignCenter)
        MainWindow.show()
        sys.exit(app.exec_())
运行代码,测试结果如下:
从此再也不用担心我用Python不会写UI了
踩坑指南:
  配置与加载QT Designer问题
VCRUNTIME140_1.dll无法找到问题!
搜索,下载这个文件,然后扔到windows/system32下面就好啦,亲测有效。
2. 无法加载Platform问题,导致QT Desinger启动失败
需要把
C:\Users\Administrator\AppData\Local\Programs\Python\Python36\Lib\site-packages\qt5_applications\Qt\plugins
目录下的platform整个文件夹copy到
目录下,然后再启动就好啦
君子藏器于身,待时而动
  推荐阅读
