Eplan Version 2027Eplan 2027 版本 <ms-cmark-node>Status: 08. April 2026</ms-cmark-node><ms-cmark-node></ms-cmark-node>
<ms-cmark-node>状态:2026年4月8日</ms-cmark-node> <ms-cmark-node></ms-cmark-node> <ms-cmark-node>Overview of the interfaces to PLC configuration programs</ms-cmark-node>
<ms-cmark-node>PLC 组态程序接口概览</ms-cmark-node>
Eplan switches the PLC data exchange with Eplan to the AutomationML industry standard in the variant "Application Recommendation Automation Project Configuration" (short: "AML AR APC").<ms-cmark-node></ms-cmark-node>
Eplan 将 PLC 数据交换切换为 AutomationML 行业标准,具体版本为“自动化项目组态应用建议”(简称:“AML AR APC”)。 The following interfaces are available for Version 2027:<ms-cmark-node></ms-cmark-node>
以下接口适用于 2027 版本: <ms-cmark-node><ms-cmark-node>Beckhoff TwinCAT 3</ms-cmark-node> / 倍福 TwinCAT 3</ms-cmark-node>
<ms-cmark-node><ms-cmark-node>Bosch Nexeed Automation</ms-cmark-node> / 博世 Nexeed Automation</ms-cmark-node>
<ms-cmark-node>logi.cals logi.CAD 3</ms-cmark-node>
<ms-cmark-node><ms-cmark-node>MELSOFT iQ-Works Version 2.46Y or later / Version 2.74C or later</ms-cmark-node> / MELSOFT iQ-Works 2.46Y 或更高版本 / 2.74C 或更高版本</ms-cmark-node>
<ms-cmark-node><ms-cmark-node>Omron Sysmac Studio 1.50 or later</ms-cmark-node> / 欧姆龙 Sysmac Studio 1.50 或更高版本</ms-cmark-node>
<ms-cmark-node><ms-cmark-node>Phoenix Contact PLCnext Engineer 2019</ms-cmark-node> / 菲尼克斯电气 PLCnext Engineer 2019</ms-cmark-node>
<ms-cmark-node><ms-cmark-node>Rockwell Automation - Studio 5000 Logix Designer</ms-cmark-node> / 罗克韦尔自动化 - Studio 5000 Logix Designer</ms-cmark-node>
<ms-cmark-node><ms-cmark-node>Siemens SIMATIC STEP 7 TIA Portal 19 / 20 / 21</ms-cmark-node> / 西门子 SIMATIC STEP 7 TIA Portal 19 / 20 / 21</ms-cmark-node>
<ms-cmark-node><ms-cmark-node>Siemens TIA Selection Tool</ms-cmark-node> / 西门子 TIA Selection Tool</ms-cmark-node>
<ms-cmark-node>Eplan Electric P8</ms-cmark-node>
The following interfaces are available on the basis of the Eplan PLC standard exchange format V1.0 / V2.0:<ms-cmark-node></ms-cmark-node>
基于 Eplan PLC 标准交换格式 V1.0 / V2.0,提供以下接口: <ms-cmark-node><ms-cmark-node>ABB Automation Builder</ms-cmark-node> / ABB Automation Builder</ms-cmark-node>
<ms-cmark-node><ms-cmark-node>B&R Automation Studio</ms-cmark-node> / 贝加莱 Automation Studio</ms-cmark-node>
<ms-cmark-node><ms-cmark-node>Bosch Rexroth Indra Works</ms-cmark-node> / 博世力士乐 Indra Works</ms-cmark-node>
Other available interfaces:<ms-cmark-node></ms-cmark-node>
其他可用接口: <ms-cmark-node><ms-cmark-node>Schneider Unity Pro 10.0 / 11.1</ms-cmark-node> / 施耐德 Unity Pro 10.0 / 11.1</ms-cmark-node>
<ms-cmark-node><ms-cmark-node>Siemens SIMATIC STEP 7 5.6</ms-cmark-node> / 西门子 SIMATIC STEP 7 5.6</ms-cmark-node>
The PLC configuration programs are available in different versions.<ms-cmark-node></ms-cmark-node>
PLC 组态程序提供有不同的版本。 Your PLC manufacturer will keep you informed about the current version statuses and the interfaces for Eplan contained in them.<ms-cmark-node></ms-cmark-node>
您的 PLC 制造商将随时向您通报当前的版本状态以及其中包含的 Eplan 接口。
