今天用分享一个C开发的  TCP 调试工具,下载链接在最后有贴出,重要的是我们通过这个工具开发熟悉C的编程基本技巧,重点巩固一下前两节的内容:C重难点1:委托  C基础委托2C重难点2:事件
配合sscom助手当TCP Server端跑起来的效果,接下来一步步讲述开发过程。(如遇大段代码,可用电脑端直接复制到vs或者notepad++中更方便查看,注意看看代码的对新手友好型的注释。)
1 先利用VS自带的socket类来写好TCP_CORE:
类目录如下:
点击查看TCP_CORE class的完整代码
using  System;
using  System.Collections.Generic;
using  System.Diagnostics;
using  System.Linq;
using  System.Net;
using  System.Net.Sockets;
using  System.Text;
using  System.Text.RegularExpressions;
using  System.Threading.Tasks;
using  System.Windows.Forms;
namespaceWindowsFormsApp1
//【01】声明委托
publicdelegatevoidSetListBoxDelegate(string  str);
classTCP_Core
//【02】创建委托对象
public  SetListBoxDelegate SetLibxBoxDelegate;
private  Socket _socket;//定义私有字段存放soket句柄
privatestring  IP;
privateint  port;
privateint  receiveCount =  0;
privateint  sendCount =  0;
private  Boolean isConnected =  false;
public  Boolean IsConnected {
get  {  return  isConnected; }
set  { isConnected =  value; }
publicint  SendCount {  get  {  return  sendCount; } }
publicint  RecieveCount {
get  {  return  receiveCount; }
publicvoidResetCount()  {
                  sendCount =  0;
                  receiveCount =  0;
public  Socket Socket
            {//提供给外部访问的属性
get  {  return  _socket; }
set  { _socket =  value; }
privatevoidGetIP_PortByParameter(string  par  )  {//从参数获取到IP和port
string  st = par.Trim( );
string[] sArray = st.Split(':');// 一定是单引
                  IP = sArray[0];
                  port =Convert.ToInt32(sArray[1]);
publicintTCP_Open(string  par  )  {
try
                        Socket client_socket =  new  Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
                        GetIP_PortByParameter(par);
                        IPAddress ipAdress = IPAddress.Parse(IP);
//网络端点:为待请求连接的IP地址和端口号
                        IPEndPoint ipEndpoint =  new  IPEndPoint(ipAdress, port);
//connect()向服务端发出连接请求。客户端不需要bind()绑定ip和端口号,
//因为系统会自动生成一个随机的地址(具体应该为本机IP+随机端口号)
                        client_socket.Connect(ipEndpoint);
                        _socket = client_socket;
                        isConnected =  true;
return0;
catch  (Exception)
                        _socket =  null;
return-1;
publicintTCP_Send(  Socket sk,string  sd  )  {
try
if  (isConnected)
                              sk.Send(Encoding.UTF8.GetBytes(sd));
                              sendCount += sd.Length;
return0;
return-1;
catch  (Exception)
return-1;
publicenum  EndChar
                  None=0,
                  OD=1,
                  OA=2,
                  ODOA=3,
publicintTCP_Read(  Socket sk,  string  match, EndChar endChar,  int  timeout_ms,outstring  str)  {
                  str =  "NullYK";
if  (isConnected)
                        Stopwatch stopwatch =  new  Stopwatch( );
string  recvStr =  "";
byte[] recvBytes =  newbyte[1024];
int  bytes;
                        stopwatch.Start( );
                        sk.ReceiveTimeout = timeout_ms;
while  (true)
try
                                          bytes = sk.Receive(recvBytes, recvBytes.Length, SocketFlags.None);//从客户端接受信息
                                          recvStr += Encoding.ASCII.GetString(recvBytes,  0, bytes);
                                          receiveCount += bytes;
if  (recvStr.Length !=  0  )
                                                SetListBox(recvStr);
break;
elseif  (stopwatch.ElapsedMilliseconds > timeout_ms);//超时退出while;)
break;
catch  (Exception)
break;
if  (match !=  null)
if  (recvStr.Contains(match))
                                          str = recvStr;
return0;
else//没有match标志就判断结束符;
switch  (endChar)
case  EndChar.None:
break;
case  EndChar.OD:
if  (recvStr.Contains("\r"))
                                                      str = recvStr;
return0;
break;
case  EndChar.OA:
if  (recvStr.Contains("\n"))
                                                      str = recvStr;
return0;
break;
case  EndChar.ODOA:
if  (recvStr.Contains("\r\n"))
                                                      str = recvStr;
return0;
break;
default:
break;
                        str = recvStr;
return0;
privatevoidSetListBox(string  dataREC  )  {
if  (dataREC.Length >  0)
                     String   str =  $"{CommonTool.GetShortTimeMillisecond( )}←⯁{dataREC}";
                        SetLibxBoxDelegate?.Invoke(str);//【执行委托】
publicintTCP_Close(  Socket sk  )  {
if  (isConnected)
                        sk.Close( );
                        sk.Dispose( );
return0;
说明下:这个委托的目的,用来在此类中能操作触发对界面控件的刷新。
2 Form1的编程:
<summary>点击查看Form1代码</summary>
<code>using  System;
using  System.ComponentModel;
using  System.Data;
using  System.Drawing;
using  System.Linq;
using  System.Reflection;
using  System.Text;
using  System.Threading;
publicpartialclassForm1  :  Form
            Form2 form2=null;
readonly  TCP_Core TCP_Core1 =  new  TCP_Core( );
readonly  CommonTool commonTool =  new  CommonTool();
privatestring  dataREC =  "";
constint  Intervaltime =  2000;//读取中断时间
public  Boolean AppIsRun =  false;
///<summary>
///  具体刷新Listbox的函数
///</summary>
///<param name="str">
///  定义一个委托(delegate),委托(delegate)可以将参数与方法传递给控件所在的线程,并由控件所在的线程执行,通过Invoke来调用,这样可以完美的解决此类问题。
publicvoidRefreshLisBox(String str  )  {//【03】委托函数(匿名委托),否则独立线程中试图刷新界面,会报错
                  Action action = ( ) =>
                        listBox1.Items.Add(str);
                        ScrollListBox(listBox1);
                        toolStripStatusLabelSendcount.Text = TCP_Core1.SendCount.ToString( );
                        toolStripStatusLabelReceive.Text = TCP_Core1.RecieveCount.ToString( );
//更新数据到Form2的dataGridView控件上
if  (form2!=null)
                              form2.newString = str;
                              form2.SetNewString( );
                  Invoke(action);
publicForm1()  {
                  InitializeComponent( );
//【04】委托绑定
                  TCP_Core1.SetLibxBoxDelegate+= RefreshLisBox;
privatevoidbutton1_Click(object  sender, EventArgs e  )  {
if  (TCP_Core1.TCP_Open(textBox1.Text) ==  0)
                        listBox1.Items.Add($"Connect [{textBox1.Text}] Successfully.");
                        btn_send.Enabled =  true;
                        btn_close.Enabled =  true;
this.toolStripStatusLabel0.Text =  "Ready";
//Task task = new Task(TaskReadLoop);
//task.Start( );
                        Thread thread1 =  new  Thread(TaskReadLoop);//独立线程运行TCP接受函数,此函数内部有 执行委托TCP_Core1.SetLibxBoxDelegate 动作
                        thread1.Start( );
                        timer1.Start( );
else
                        listBox1.Items.Add("Connect Failed.");
this.toolStripStatusLabel0.Text =  "Error";
                        timer1.Stop( );
privatevoidbtnSend_Click(object  sender, EventArgs e  )  {
string  data =  $"{CommonTool.GetShortTimeMillisecond( )}→⟐{textBox2.Text}";
                  listBox1.Items.Add(data);
                  TCP_Core1.TCP_Send(TCP_Core1.Socket,textBox2.Text );
                  ScrollListBox( listBox1);
if  (form2!=null)
                        form2.newString = data;
privatevoidbutton3_Click(object  sender, EventArgs e  )  {
                  timer1.Stop( );
                  btn_open.Enabled =  true;
                  btn_send.Enabled =  false;
                  btn_close.Enabled =  false;
                  TCP_Core1.IsConnected =  false;
                  TCP_Core1.TCP_Close( TCP_Core1.Socket);
privatevoidForm1_Load(object  sender, EventArgs e  )  {
                  textBox1.Text =  "127.0.0.1:7200";
                  textBox2.Text =  "yk test TCP CORE";
                  tableLayoutPanel1.Dock = DockStyle.Fill;
                  timer1.Interval =100;
this.Text =  "TCP Debug Tool";
                  label1.Text =  "Log:";
                  label2.Text =  "IP:port";
                  label3.Text =  "Send:";
                  listBox1.Items.Clear( );
                  listBox1.GetType( ).GetProperty("DoubleBuffered", System.Reflection.BindingFlags.Instance | System.Reflection.BindingFlags.NonPublic).SetValue(listBox1,  true,  null);
this.toolStripStatusLabel0.Text =  "Please Open a connection";
                  AppIsRun =  true;
privatevoidScrollListBox(ListBox listBox  )  {//在添加新记录前,先计算滚动条是否在底部,从而决定添加后是否自动滚动。
// 既可以在需要时实现自动滚动,又不会在频繁添加记录时干扰用户对滚动条的控制。
int  ctl_rows =Convert.ToInt32( listBox1.Height /  this.listBox1.ItemHeight);
if  (listBox1.Items.Count > (ctl_rows -  1)){
                        listBox1.TopIndex = listBox1.Items.Count - ctl_rows+3;
else  {
                        listBox1.TopIndex =  0;
publicvoidTaskReadLoop()  {
while  (AppIsRun)
                        TCP_Core1.TCP_Read(TCP_Core1.Socket,  null, TCP_Core.EndChar.ODOA, Intervaltime,  out  dataREC);
privatevoidtimer1_Tick(object  sender, EventArgs e  )  {
//在timer里面来接受数据会造成界面卡顿。
privatevoidbtn_clear_Click(object  sender, EventArgs e  )  {
if  (form2!=null)
                        form2.CleardataGridView( );
                  TCP_Core1.ResetCount( );
privatevoidcheckBox1_CheckedChanged(object  sender, EventArgs e  )  {
                 commonTool.Enable= checkBox1.Checked;
privatevoidbutton1_Click_1(object  sender, EventArgs e  )  {
privatevoidgroupBox1_Enter(object  sender, EventArgs e  )  {
privatevoidopenTestWindowToolStripMenuItem_Click(object  sender, EventArgs e  )  {
if  (form2==null)
                              form2 =  new  Form2( );
                              form2.NewDataIn += form2.OnNewString;//[A4]挂接委托
                              form2.Show( );
else
                        form2.Visible =  true;
privatevoidtb_time_TextChanged(object  sender, EventArgs e  )  {
privatevoidForm1_FormClosing(object  sender, FormClosingEventArgs e  )  {
if  (MessageBox.Show("Are you sure to exit?","Information",MessageBoxButtons.YesNo,MessageBoxIcon.Question)==DialogResult.Yes)
                        TCP_Core1.TCP_Close(TCP_Core1.Socket);
                        AppIsRun =  false;
                        e.Cancel =  false;
else
                        e.Cancel =  true;
这里有几点重要的要说明:
(1)我们定义了一个一直循环接受的方法:
<code>publicvoidTaskReadLoop()  {
while  (AppIsRun)
AppIsRun是存储软件是否在运行的字段;
(2)如果我们把上述TaskReadLoop( )直接在界面线程中运行的话,那么UI就会卡死;
所以我们得单独开辟个线程来运行:
<code>privatevoidbutton1_Click(object  sender, EventArgs e  )  {
//task.Start( );
                        thread1.Start( );
(3)委托 TCP_Core1.SetLibxBoxDelegate+= RefreshLisBox的挂接的方法,RefreshLisBox这里要使用匿名委托,否则会报错:不可以跨线程访问Listbox控件;
<code>publicvoidRefreshLisBox(String str )  {//【03】委托函数(匿名委托),否则独立线程中试图刷新界面,会报错
Actionaction=  ( ) =>
if  (form2!=null)
                  Invoke(action);
3 Form2的编程
由于Form1上使用的Listbox控件来显示收发数据记录,会发生闪烁,尤其是在将窗口最大化时候,更明显。尝试了很多方法,比如 开双缓存等,几乎没效果。
而Form2上我用dataGridView来显示收发数据记录,我们会发现,同样的情况下,dataGridView控件不闪烁。关于Form2有几个知识点:
(1)如何将收发的数据也能同时传到Form2上的dataGridView控件?
Form2的文件列表:
为了当有新的数据传过来时,有变量存储,我们首先定义了一个 字段:
public string newString= "";
然后定义了一个自定义事件——
代码:
<code>namespaceWindowsFormsApp1
publicdelegatevoiddeleUserEvent();//【A1】声明委托类型
publicpartialclassForm2  :  Form
publicevent  deleUserEvent NewDataIn =  null;//[A2]声明Form2类的一个事件
publicstring  newString=  "";
当有新的数据时触发事件,我们的事件处理器如下:
<code>publicvoidOnNewString( ){//[A3]事件处理器
                  dataGridView1.Rows.Add(newString);
this.dataGridView1.FirstDisplayedScrollingRowIndex = dataGridView1.Rows[dataGridView1.Rows.Count -  1].Index;
事件的挂架:在打开Form2窗口时,我们变用Form2自己的事件处理器来挂接自己的事件
<code>privatevoidopenTestWindowToolStripMenuItem_Click(object  sender, EventArgs e  ) {
if  (form2==null)
                              form2 =  newForm2( );
                              form2.Show( );
else
接下来在Form1中修改如下RefreshListBox代码:
if  (form2!=null)
                  Invoke(action);
其中form2.SetNewString( )的方法是为了执行委托:
<code>publicvoidSetNewString()  {
                  NewDataIn?.Invoke( );//【A5】执行方法
<summary>点击查看Form2的完整代码</summary>
<code>using  System;
using  System.Data;
using  System.Linq;
using  System.Text;
publicvoidCleardataGridView()  {
                  dataGridView1.Rows.Clear( );
publicvoidOnNewString()  {//[A3]事件处理器
publicForm2()  {
///  新添加这一句调用就行了,如果有ListViews也是这样添加,
///  但要注意方法里改为有关ListViews的声明即可
                  dataGridView1.DoubleBufferedDataGirdView(true);
this.Text =  "Showed in \"dataGridView\"";
privatevoidForm2_Load(object  sender, EventArgs e  )  {
                  dataGridView1.Columns.Add(  "data","Data");
                  dataGridView1.Columns.Add(  "Note","note");
                  dataGridView1.AutoSizeColumnsMode = DataGridViewAutoSizeColumnsMode.AllCells;
                  dataGridView1.Rows.Add(  "test data show with no shake!!!!");
                  dataGridView1.Dock = DockStyle.Fill;
privatevoidForm2_FormClosing(object  sender, FormClosingEventArgs e  )  {
                  e.Cancel =  true;
this.Visible =  false;
publicstaticclassDoubleBufferDataGridView
///<summary>
///  双缓冲,解决闪烁问题
///</summary>
publicstaticvoidDoubleBufferedDataGirdView(this  DataGridView dgv,  bool  flag  )  {
                  Type dgvType = dgv.GetType( );
                  PropertyInfo pi = dgvType.GetProperty("DoubleBuffered", BindingFlags.Instance | BindingFlags.NonPublic);
                  pi.SetValue(dgv, flag,  null);
4 还有一个CommonTool类
这个类用来获取各种格式的时间信息,几个方法都返回不同格式的时间字符串,有一个enable属性控制是否启用;
<summary>点击查看class CommonTool代码</summary>
<code>using  System;
using  System.Linq;
using  System.Text;
/*This class contain some unival tool like time stamp,string convertion etc.*/
classCommonTool
staticbool  enable=false;
staticstring  formattedDateTime =  string.Empty;
publicbool  Enable {  get  {  return  enable; }   set  { enable =  value; } }
publicstaticstringGetLongTime()  {
if  (enable)
                        DateTime dateTime = DateTime.Now;
                        formattedDateTime = dateTime.ToString("[yyyy-MM-dd HH:mm:ss]");  //
else
return  formattedDateTime;
publicstaticstringGetShortTime()  {
if  (enable)
                        formattedDateTime = dateTime.ToString("[HH:mm:ss]");  //
else
publicstaticstringGetShortTimeMillisecond()  {
if  (enable)
                        formattedDateTime = dateTime.ToString("[HH:mm:ss.fff]");  //
else
如果有些无法展开看代码的部分,请移步我的博客:
https://www.cnblogs.com/StephenYoung/p/18381337
看得更清楚,舒服。
需要整个完整项目文件,请后台私信我,或者加我微信。
打包成TCP Debug Tool.exe后的下载链接,解压缩密码:LabVIEW9527
__EOF__
</code></code></code></code></code></code></code></code></code></code></code>
