using System;using System.Drawing;using System.Drawing.Drawing2D;using System.Windows.Forms;using System.ComponentModel;namespace CustomControls{ /// <summary> /// 自定义样式按钮控件 /// 支持圆角、渐变背景、悬停/点击状态切换、自定义文字颜色 /// </summary> public class CustomStyleButton : Button { #region 私有字段 // 圆角半径(默认10px) private int _cornerRadius = 10; // 渐变起始颜色(默认浅蓝色) private Color _gradientStartColor = Color.LightSkyBlue; // 渐变结束颜色(默认深蓝色) private Color _gradientEndColor = Color.RoyalBlue; // 悬停状态渐变起始颜色 private Color _hoverStartColor = Color.LightBlue; // 悬停状态渐变结束颜色 private Color _hoverEndColor = Color.DodgerBlue; // 点击状态渐变起始颜色 private Color _pressedStartColor = Color.SkyBlue; // 点击状态渐变结束颜色 private Color _pressedEndColor = Color.Blue; // 按钮文字颜色(默认白色) private Color _buttonTextColor = Color.White; #endregion #region 公共属性(支持设计时编辑) /// <summary> /// 按钮圆角半径 /// </summary> [Description("按钮圆角半径(值越大圆角越明显)"), Category("自定义按钮样式")] public int CornerRadius { get => _cornerRadius; set { _cornerRadius = Math.Max(0, value); // 防止负数 Invalidate(); // 属性变更时重绘控件 } } /// <summary> /// 正常状态渐变起始颜色 /// </summary> [Description("正常状态下渐变起始颜色"), Category("自定义按钮样式")] public Color GradientStartColor { get => _gradientStartColor; set { _gradientStartColor = value; Invalidate(); } } /// <summary> /// 正常状态渐变结束颜色 /// </summary> [Description("正常状态下渐变结束颜色"), Category("自定义按钮样式")] public Color GradientEndColor { get => _gradientEndColor; set { _gradientEndColor = value; Invalidate(); } } /// <summary> /// 鼠标悬停状态渐变起始颜色 /// </summary> [Description("鼠标悬停时渐变起始颜色"), Category("自定义按钮样式")] public Color HoverStartColor { get => _hoverStartColor; set { _hoverStartColor = value; Invalidate(); } } /// <summary> /// 鼠标悬停状态渐变结束颜色 /// </summary> [Description("鼠标悬停时渐变结束颜色"), Category("自定义按钮样式")] public Color HoverEndColor { get => _hoverEndColor; set { _hoverEndColor = value; Invalidate(); } } /// <summary> /// 鼠标点击状态渐变起始颜色 /// </summary> [Description("鼠标点击时渐变起始颜色"), Category("自定义按钮样式")] public Color PressedStartColor { get => _pressedStartColor; set { _pressedStartColor = value; Invalidate(); } } /// <summary> /// 鼠标点击状态渐变结束颜色 /// </summary> [Description("鼠标点击时渐变结束颜色"), Category("自定义按钮样式")] public Color PressedEndColor { get => _pressedEndColor; set { _pressedEndColor = value; Invalidate(); } } /// <summary> /// 按钮文字颜色 /// </summary> [Description("按钮显示文字的颜色"), Category("自定义按钮样式")] public Color ButtonTextColor { get => _buttonTextColor; set { _buttonTextColor = value; Invalidate(); } } #endregion #region 构造函数 public CustomStyleButton() { // 初始化按钮基础样式 this.FlatStyle = FlatStyle.Flat; // 隐藏默认边框和样式 this.FlatAppearance.BorderSize = 0; // 移除默认边框 this.SetStyle(ControlStyles.AllPaintingInWmPaint | ControlStyles.OptimizedDoubleBuffer | ControlStyles.ResizeRedraw | ControlStyles.UserPaint, true); // 开启双缓冲,防止闪烁 this.DoubleBuffered = true; this.Font = new Font("微软雅黑", 9F, FontStyle.Regular, GraphicsUnit.Point); // 默认字体 } #endregion #region 核心重写方法:OnPaint(绘制自定义按钮样式) /// <summary> /// 重写OnPaint方法,实现自定义按钮的绘制逻辑 /// </summary> /// <param name="e">绘图事件参数 protected override void OnPaint(PaintEventArgs e) { base.OnPaint(e); Graphics g = e.Graphics; g.SmoothingMode = SmoothingMode.AntiAlias; // 开启抗锯齿,使圆角和文字更平滑 g.TextRenderingHint = System.Drawing.Text.TextRenderingHint.ClearTypeGridFit; // 文字高清渲染 // 1. 定义按钮绘制区域(排除内边距,适配按钮大小) Rectangle buttonRect = new Rectangle(0, 0, this.Width - 1, this.Height - 1); // 2. 创建圆角路径(核心:实现圆角按钮) using (GraphicsPath buttonPath = new GraphicsPath()) { // 添加圆角矩形到路径(四个角统一圆角半径) buttonPath.AddArc(buttonRect.X, buttonRect.Y, _cornerRadius, _cornerRadius, 180, 90); // 左上角 buttonPath.AddArc(buttonRect.Right - _cornerRadius, buttonRect.Y, _cornerRadius, _cornerRadius, 270, 90); // 右上角 buttonPath.AddArc(buttonRect.Right - _cornerRadius, buttonRect.Bottom - _cornerRadius, _cornerRadius, _cornerRadius, 0, 90); // 右下角 buttonPath.AddArc(buttonRect.X, buttonRect.Bottom - _cornerRadius, _cornerRadius, _cornerRadius, 90, 90); // 左下角 buttonPath.CloseAllFigures(); // 闭合路径 // 3. 根据按钮状态选择对应的渐变颜色 LinearGradientBrush gradientBrush = null; if (this.ClientRectangle.Contains(this.PointToClient(Cursor.Position)) && this.MouseButtons == MouseButtons.Left) { // 状态1:鼠标点击(按住) gradientBrush = new LinearGradientBrush(buttonRect, _pressedStartColor, _pressedEndColor, LinearGradientMode.Vertical); } else if (this.ClientRectangle.Contains(this.PointToClient(Cursor.Position))) { // 状态2:鼠标悬停 gradientBrush = new LinearGradientBrush(buttonRect, _hoverStartColor, _hoverEndColor, LinearGradientMode.Vertical); } else { // 状态3:正常状态(无交互) gradientBrush = new LinearGradientBrush(buttonRect, _gradientStartColor, _gradientEndColor, LinearGradientMode.Vertical); } // 4. 绘制按钮背景(渐变+圆角) using (gradientBrush) { g.FillPath(gradientBrush, buttonPath); } // 5. 绘制按钮边框(增强质感,半透明黑色) using (Pen borderPen = new Pen(Color.FromArgb(50, Color.Black), 1)) { g.DrawPath(borderPen, buttonPath); } // 6. 绘制按钮文字(居中显示) using (SolidBrush textBrush = new SolidBrush(_buttonTextColor)) { // 文字居中布局 StringFormat stringFormat = new StringFormat { Alignment = StringAlignment.Center, LineAlignment = StringAlignment.Center }; g.DrawString(this.Text, this.Font, textBrush, buttonRect, stringFormat); } } } #endregion }}
三、控件使用方法
步骤 1:添加控件到窗体
将上述代码编译为类库(或直接放在 WinForms 项目中)
在 Visual Studio 工具箱中,右键→「选择项」→「浏览」→ 选中编译后的程序集,确认后CustomStyleButton会出现在工具箱中
直接拖拽CustomStyleButton到 WinForms 窗体上,可自由调整按钮大小
步骤 2:使用方式(设计时 + 运行时)
1. 设计时配置(可视化操作)
选中窗体上的CustomStyleButton,在「属性」窗口中找到「自定义按钮样式」分类,可直接修改:
圆角半径(CornerRadius)
各状态渐变颜色(正常 / 悬停 / 点击)
文字颜色(ButtonTextColor)
文字内容(Text)、字体(Font)等基础属性
2. 运行时动态修改(代码控制)
using System;using System.Drawing;using System.Windows.Forms;using CustomControls;namespace CustomButtonDemo{ public partial class FrmMain : Form { public FrmMain() { InitializeComponent(); } // 示例1:动态修改按钮样式 private void btnSetStyle_Click(object sender, EventArgs e) { // 修改圆角半径为20 customStyleButton1.CornerRadius = 20; // 修改正常状态渐变颜色(红→深红) customStyleButton1.GradientStartColor = Color.LightCoral; customStyleButton1.GradientEndColor = Color.DarkRed; // 修改文字颜色为黄色 customStyleButton1.ButtonTextColor = Color.Yellow; } // 示例2:动态修改按钮文字 private void btnSetText_Click(object sender, EventArgs e) { customStyleButton1.Text = "动态修改的按钮文字"; } // 示例3:绑定按钮点击事件(与默认Button用法一致) private void customStyleButton1_Click(object sender, EventArgs e) { MessageBox.Show("自定义按钮被点击了!"); } }}
四、关键特性说明
核心继承:直接继承System.Windows.Forms.Button,完全复用默认按钮的所有交互逻辑(点击事件、焦点、禁用状态等),无需额外封装事件
个性化样式圆角效果:通过GraphicsPath绘制圆角矩形,圆角半径可自定义
渐变背景:支持垂直渐变,正常 / 悬停 / 点击三种状态分别对应独立渐变颜色
高清渲染:开启抗锯齿和文字高清渲染,样式更细腻
状态切换:自动识别鼠标「正常」「悬停」「点击」三种状态,自动切换样式,无需手动处理鼠标事件
设计时支持:通过[Description]和[Category]特性,属性可在 VS 属性窗口中分类显示,可视化配置更便捷
无闪烁:开启双缓冲和优化绘制样式,避免控件重绘时出现闪烁问题
高可复用性:一次封装,可在多个项目中拖拽使用,支持动态修改样式
