step7 5.4 安装求助
查看2031 | 回复2 | 2008-3-31 09:55:00 | 显示全部楼层 |阅读模式
初学西门子 ,请教各位高手 帮忙看一下这是什么问题,万分感谢!!!安装中到安装自动授权时出现的问题提示
you must fulfil the following requirements to be able to install automation license manager
on you computer successfully
tht server-service is not installed or hasnt been started!
the automation license manager is not available by the networt and can only use license keys locally
the server-service is deactivated
the automation license manager is not available to install
万分感谢!!
ming7239 | 2008-3-31 09:58:00 | 显示全部楼层
这是我安装时出现的问题截图
jigexu | 2008-4-13 08:01:00 | 显示全部楼层
没碰到过,是不是安装授权管理器时出的?看字面的意思可能是那个服务没打开,猜的。要不重启一下。
