[西门子] KUKA机器人VASS标准涂胶PLC通讯控制分析
查看112 | 回复0 | 2025-3-30 15:04:38 | 显示全部楼层 |阅读模式
IF $FLAG[F_m_KL1] THEN F542 使用涂胶
 MIT_Kleben_1=TRUE
 ELSE
 MIT_Kleben_1=FALSE
 ENDIF
 IF MIT_Kleben_1 THEN 使用涂胶功能
$OUT[O_KL1_o_Proz]=$IN[I_KL1_o_Proz] OR $IN[I_FT_o_BT] OR   $FLAG[F_o_Prozess]
–A1530涂胶工具不启动-E161涂胶不使用-E15空运转-F525关闭工具
   涂胶系统启动
$OUT[O_KL1_SYS_EIN]=TRUE
A1545系统部件启动
 节能功能
$OUT[O_KL1_E_Mode]=($Brake_Sig==0) AND $IN[I_R_E_Mode]
A1546节能模式打开抱闸没有释放—E29PLC节能功能激活
 零件展示
$OUT[O_KL1_BT_zei]=$IN[I_KL1_BT_zei] AND $OUT[O_KL1_P_akt]
A1548涂胶展示=E162PLC选择去展示位置-A161工具启动
 清胶
 IF NOT $OUT[O_KL1_P_akt] THEN 如果没有A161开始涂胶
 IF ($OUT[O_R_PFO] AND NOT KL1_stat AND $FLAG[F_KL1_FRG_PF0]) OR (KL1_stat AND $IN[I_Sp_Ruh_KL1] AND NOT $IN[I_Sp_Arb_KL1]) THEN
 F721 激活在原位清胶功能, F365固定胶KL1_stat,E2115摆臂胶桶摆回E2116摆臂胶桶伸出
 $OUT[O_KL1_FRG_SP]=TRUE  A1534清胶许可
 ELSE
 $OUT[O_KL1_FRG_SP]=FALSE
 ENDIF
 IF MIT_KL1_SPUELEN OR $IN[I_KL1_anw_Sp] THEN原位清胶F346A163选择清胶
 IF ($EXT==TRUE) AND $COULD_START_MOTION AND $OUT[O_KL1_FRG_SP] THEN
 IF $IN[I_KL1_ANF_SP] OR $IN[I_KL1_anw_Sp] THEN
 $OUT[O_KL1_SP_EIN]=TRUE    A1535冲洗清胶
 $OUT[O_KL1_Sp_akt]=TRUE
 KL1_SPUELEN_AKTIV=TRUE  激活清胶
 ENDIF
 IF $IN[I_KL1_SP_FER] THEN  E1536清胶结束
 $OUT[O_KL1_SP_EIN]=FALSE
 $OUT[O_KL1_Sp_akt]=FALSE
 KL1_SPUELEN_AKTIV=FALSE
 ENDIF
 ENDIF
 ENDIF
ENDIF
-------关闭清胶-----------
 IF MIT_KL1_SPUELEN AND ((NOT $OUT[O_R_PFO] AND NOT KL1_stat) OR (KL1_stat AND NOT $IN[I_Sp_Ruh_KL1]) OR ($EXT==FALSE)) AND KL1_SPUELEN_AKTIV THEN
 ENDIF
 节能模式启动
$OUT[O_KL1_E_Mod]=$OUT[O_R_Auto] AND $IN[I_KL1_E_Mode]
---A1546节能模式激活—A12机器人自动-E1546涂胶节能模式激活
 ;预警已开启
$OUT[O_KL1_VW_akt]=$OUT[O_R_Auto] AND $IN[I_KL1_VW_akt]
---A165预警启动  ----E1552 涂胶预警信号
 ; 桶警告
$OUT[O_KL1_VW_Fas]=$OUT[O_R_Auto] AND $IN[I_KL1_VW_Fas]
---A166胶桶警告----E1549胶桶预警
 ;未达到过程温度
$OUT[O_KL1_P_Temp]=$OUT[O_R_Auto] AND $COULD_START_MOTION AND NOT $OUT[O_R_PFO] AND NOT $IN[I_KL1_P_Temp] AND NOT KL1_o_Nachtrig
A167未达到过程温度-E1551加热温度合格- KL1_o_Nachtrig F336不启用自动加热
 故障加热//加液单元
$OUT[O_KL1_St_HPD]=$OUT[O_R_Auto] AND $COULD_START_MOTION AND NOT $IN[I_KL1_St_HPD] AND NOT KL1_o_Nachtrig
A168加热//加液单元故障-E1548加热、泵无故障
 ;错误胶粘剂的应用
$OUT[O_KL1_Feh_KL]=$OUT[O_R_Auto] AND NOT $IN[I_KL1_Feh_KL]
A169涂胶故障 –E1526喷胶无错误
 ;1K im Mischer 在搅拌机中1K
$OUT[O_KL1_1K_Mix]=$OUT[O_R_Auto] AND $IN[I_KL1_1K_Mix]
A170 – E1554混和器1
 ;2K im Mischer在搅拌机中2K
 $OUT[O_KL1_2K_Mix]=$OUT[O_R_Auto] AND $IN[I_KL1_2K_Mix]
 ;控制测量完成
$OUT[O_KL1_FK_Kon]=$OUT[O_R_Auto] AND $IN[I_KL1_FK_Kon]
A173 –E1564
 清空余额
$OUT[O_KL1_Waa_le]=$OUT[O_R_Auto] AND $IN[I_KL1_Waa_le]
A174要求混合器更换  E1562 清空
 ;准备就绪故障
$OUT[O_KL1_Betr_f]=$OUT[O_R_Auto] AND $COULD_START_MOTION AND NOT $IN[I_KL1_Betr_f] AND $timer_flag[TimerNr_Ein]
A175涂胶准备就绪故障-E1527准备就绪
 ;Sammelstoerung
$OUT[O_KL1_Sammel]=$OUT[O_R_Auto] AND $COULD_START_MOTION AND (NOT $IN[I_KL1_Sammel] OR $FLAG[F_KL1_Sammel]) AND $timer_flag[TimerNr_Ein]
A176 总故障  -E1524无故障—F347 涂胶故障
 ENDIF
 ;ENDFOLD
