[CodeSys] CODESYS Press Release
查看158 | 回复0 | 2025-3-25 07:51:33 | 显示全部楼层 |阅读模式
1   CODESYS V3.5 SP9版本已发布,支持PLCopen Part 4
CODESYS V3.5 SP9版本近日已发布。
新版本已支持PLCopen Part 4,在CODESYS SoftMotion CNC基础上使用,使得机器人控制器开发更加便利!同时在9月份左右,CODESYS还将继续丰富该供能模块。
Overview of the main features:
CODESYS Runtime:
  • Support of X.509 certificates
  • Consistent monitoring via PLCHandler / IecVarAccess
  • Separate provider component for CODESYS OPC UA Server
  • CODESYS Control for BeagleBone SL
CODESYS Engineering:
  • New indicators in the navigator tree
  • Graphical zoom in ST editor and in the declaration
  • Numerous useful improvements of the CFC editor, library manager, online mode, frame and CODESYS Application Composer
  • Display of projects in other languages (project localization)
  • CODESYS Test Manager with test tables for the easy generation of test cases
CODESYS Visualization:
  • New Visualization elements “Date Picker” and “Date and Time Picker”
  • Enumerations with text lists
  • Keypad text field – Input with selection
  • Event for value changes in the Visualization
  • Numerous other improvements, for example in the CODESYS Depictor
CODESYS Motion + CNC:
  • Robotics functionality integrated in CODESYS SoftMotion CNC+Robotics
CODESYS Fieldbus:
  • General extensions in device tree and device object
  • Numerous improvements in fieldbus support for CANopen, J1939, EtherCAT, PROFINET and in the IoDriver
2 CODESYS Store产品购买
CODESYS Store产品现可以从3S 中国公司直接购买!
CODESYS Store为德国3S面向终端用户开设的一个购买窗口。电子商店内有基于windows下工控机使用的CODESYS RTE Single License、多种总线、Application composer等等产品。
目前,中国公司可以向客户出售该网店产品,同时开具增值税专用发票。
产品信息可见:http://store.codesys.com/?___store=en
产品咨询:info@codesys.cn
