[img=553.739990234375,268.26995849609375]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNneSrI6ib1e1eoFlc0PKpWNSFZMOK56bxJFyWuFeEOHIia8Ud8oLEUcFAQ/640?wx_fmt=jpeg[/img]
某次活动中了个欧姆龙的电子血压计:可以测量血压,心率,小巧便携,使用简单,且只需两节电池。
[img=553.739990234375,416.2099914550781]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNndKxeK4VIs01e6P7bicz8dwicvt50GsX65b63DumMKQ7YSlflFeIGsrvA/640?wx_fmt=jpeg[/img]
[img=553.739990234375,416.21002197265625]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNn8E3PgLLN6jueae1OPusla2WjWn8USmIMjXIKqIEwjlTDeVnSRb8jZg/640?wx_fmt=jpeg[/img]
[img=553.739990234375,416.2099609375]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNndVBXZg1O5icMXVgTJ1MfVLeFtnfmibRxn7nNpRiaiaODFI3c39bdArsprQ/640?wx_fmt=jpeg[/img]
[img=553.739990234375,738.340087890625]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNngnUWZxAs4ZQWW6b2kFqILLf6Mop2UY7vW3xGkJ1ZicvibyHWhEOaAib8A/640?wx_fmt=jpeg[/img]
[img=553.739990234375,558.8800048828125]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnoktiaOOgSVaiaYxgkoA2rnmOvrRKQQblYWBnMEBJ7PcTQhIGjrCbgmaQ/640?wx_fmt=jpeg[/img]
主要参数如下:
·型号:HEM-8612
·显示:数字段码屏
·测量方式:示波测定法
·测量精度:压力:±3mmHg
·脉搏精度:±5%
·测量压力范围:0~299mmHg,脉搏:40~180次/分
·宣称符合AAMI标准(美国医疗器械促进协会),拆它看看肚子里有几碗粉儿。
[img=553.739990234375,323.5400390625]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnCykf9oyG2IQ8s8uBH2ja6Qz1ibRcWSmWZ9fxaMagC1CZicSR8cZYuA7A/640?wx_fmt=jpeg[/img]
[img=553.739990234375,263.0]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNn4C0so3Q5UnfD00B9mtPqVWEUZaZAj4RGiaw3mVlY1lvTdaxUfMibzMZA/640?wx_fmt=jpeg[/img]
[img=553.739990234375,429.1400146484375]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNntqdmN5FXkMhNaa4p2EWSl3BE1nccowo6tv1j4Y5mQJpfw8lQoC77bw/640?wx_fmt=jpeg[/img]
[img=553.739990234375,337.40997314453125]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNn0KicEatzPSqXwLteHJtW01QGDLNYjibiarL1TUYk1ZG4zCbKXLbWv6e0w/640?wx_fmt=jpeg[/img]
拿掉电池后腕带处有一颗十字螺丝,拆下来后就可以分离腕带,固定上下壳的螺丝有2个,拆掉即可分开了。
[img=553.739990234375,389.1400146484375]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnccNqYojwn6YicpDY8BQzoLoeym3I5RTOnWOLQjl2H0ibEapRlfHhss3g/640?wx_fmt=jpeg[/img]
[img=553.739990234375,373.2699890136719]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnf4LoBLhqibwgFSn8a0hth7gwPUmbibawssKXaWiaAdPKrILGZ9d3ACC9Q/640?wx_fmt=jpeg[/img]
[img=553.739990234375,354.80999755859375]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNn9LIxAxpa897rTR1X0xibqvy7rMPWOLatlZulichKJXwmSicpH0jsW9rQA/640?wx_fmt=jpeg[/img]
拿掉上盖可以看到一个段码屏两个锅仔按键(还阉割了一刀,应该是储存功能)。段码屏有专用支架支撑。
[img=553.739990234375,557.3399658203125]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNngfxjcoTruiboMJxBed3mWxEglqS9gFia87jQ1TBp5tr6iaXkeBXxXF8xQ/640?wx_fmt=jpeg[/img]
[img=553.739990234375,617.340087890625]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnqJsYDZUO9ic0aJ5KMgibLrsEn1icZAgRamtLsiaibctO348cjuIggeVWdDA/640?wx_fmt=jpeg[/img]
拿掉板子可以看到背壳里微型打气泵(给臂带充气打压),一个电磁阀(用来测量结束后放气)。
[img=553.739990234375,415.3399963378906]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNn5xibd6XwlDEzcVs8PmdW1LiaRxaVBks5ITicYssJkmVG7afmbXcmaYkDg/640?wx_fmt=jpeg[/img]
[img=553.739990234375,738.340087890625]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnbp7zNnfrQpgic20PKA5icDDN9f3KgZcHDDPibeKxJbMhu2z83SQmv3ZGQ/640?wx_fmt=jpeg[/img]
[img=553.739990234375,738.340087890625]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNn7ZnBEwYe4ibico2j6decu4kKQm0qgNTEhq3DB0148jKy2kZicJ3BrlN9w/640?wx_fmt=jpeg[/img]
[img=553.739990234375,603.47998046875]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNn46zMCuvzkPWsMSan9kWh79p6OYqujEl0iboA4A2WeFC33ELAzgJSWCw/640?wx_fmt=jpeg[/img]
[img=553.739990234375,522.469970703125]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnAo5kVRVEsdcChUsJtEa6ibcUe1UcfHHXM5vOwOkqVAUygTibSjoUpXwA/640?wx_fmt=jpeg[/img]
[img=553.739990234375,386.6700439453125]https://mmbiz.qpic.cn/mmbiz_png/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnYpemR94AicU1ZDLCibdsUA8R8Tq4IFVyHxn4cP3uFzibgxYRk0wfZ27ow/640?wx_fmt=png[/img]
主控采用东芝的T5CX3(IC1),资料是真难找啊,来自欧姆龙自己的压力传感器PP02(IC2),还有两颗eeprom BR24G08(IC3,IC4)。
[img=553.739990234375,464.53997802734375]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnNl8S98lIiahKcLOiaZnwibqHjz0nUNP2pNgVjYehicZtVfs3QmwVST94ng/640?wx_fmt=jpeg[/img]
[img=553.739990234375,415.3399658203125]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNntI1leIKUdVibCpfv8AEiao9MTvFCUMXP2OhqBH88Naic7POb0ppYPzibfQ/640?wx_fmt=jpeg[/img]
IC5应该是颗DCDC,用来驱动气泵的,LCD屏是导电胶热压上去的。
[img=553.739990234375,543.469970703125]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnktpRJjwNjOHnic0Pibg2UOJQxkVicr03I0LzDjGTWSNAaxW9VicEpNRIog/640?wx_fmt=jpeg[/img]
[img=553.739990234375,559.8800048828125]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnGjfcOq5gp0qAGcgBQMia5XIjkv08eKsibI2eTqH32k08wFGRFz1LtSdA/640?wx_fmt=jpeg[/img]
[img=553.739990234375,554.739990234375]https://mmbiz.qpic.cn/mmbiz_jpg/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnbzuYE7r3lPyZo2nKoJeIhicaBvAQKkOfmgLmbAt2HgMgKp96mrIEgeg/640?wx_fmt=jpeg[/img]
背面挺整洁的,留了好多测试点。
这款应该是8613的阉割版,可惜我手里没其他的血压仪没法对比他的精度怎么样。不过很小巧便携,测量仅需2分钟,还是挺方便的。
[img=553.739990234375,268.47003173828125]https://mmbiz.qpic.cn/mmbiz_png/xML2GYBfTfnyw0Qqic53cLycjPXCRRGNnWlGuxKmnu49ajOEibDQY22QxRJOVILM43aZ8PuqORFJ3MQkzya7uCww/640?wx_fmt=png[/img] |
