[西门子] 西门子S7-200smart正反转实现,C#仿真
查看174 | 回复0 | 2024-11-21 07:48:40 | 显示全部楼层 |阅读模式
(1)程序设计
注意互锁和自锁;
’(2)C#界面设计
(3)C#代码设计
  //读正反转驱动状态
  bool a,b;
  a = ((bool)plc.Read("M1.3"));
  b = ((bool)plc.Read("M1.4"));
  if(a)
      drive_stat.Text = "正转运行中";
  if (b)
      drive_stat.Text = "反转运行中";
  if (!(a || b))
      drive_stat.Text = "设备停止中";
 private void btn_正转启动_Click(object sender, EventArgs e)
     if (plc.IsConnected == false)
         MessageBox.Show("未连接PLC!", "连接提示", MessageBoxButtons.OK);
     else
         try
             plc.Write("M1.0", 1);
             plc.Write("M1.0", 0);
         catch (Exception Ex)
             MessageBox.Show("请检查输入的“地址”或“值”是否错误!" + Ex, "输入提示", MessageBoxButtons.OK);
 private void btn_停止_Click(object sender, EventArgs e)
     else
         try
             plc.Write("M1.2", 1);
             plc.Write("M1.2", 0);
private void btn_反转启动_Click(object sender, EventArgs e)
    else
        try
            plc.Write("M1.1", 1);
            plc.Write("M1.1", 0);
(4)演示
