[西门子] C#如何显示S7-200smart的时钟
查看96 | 回复0 | 2024-11-21 07:48:40 | 显示全部楼层 |阅读模式
效果:
PLC程序:
C#代码
 string y1;
 string m1;
 string d1;
 string h1;
 string min1;
 string sec1;
 //年
 int intValue = ((byte)plc.Read("DB1.DBB0"));
 string hexValue = intValue.ToString("X");
 y1 = hexValue;
 //月
 int intValue1 = ((byte)plc.Read("DB1.DBB1"));
 string hexValue1 = intValue1.ToString("X");
 m1 = hexValue1;
 //日
 int intValue2 = ((byte)plc.Read("DB1.DBB2"));
 string hexValue2 = intValue2.ToString("X");
 d1 = hexValue2;
 //时
 int intValue5 = ((byte)plc.Read("DB1.DBB3"));
 string hexValue5 = intValue5.ToString("X");
 h1 = hexValue5;
 //分
 int intValue3 = ((byte)plc.Read("DB1.DBB4"));
 string hexValue3 = intValue3.ToString("X");
 min1 = hexValue3;
 //秒
 int intValue4 = ((byte)plc.Read("DB1.DBB5"));
 string hexValue4 = intValue4.ToString("X");
 sec1 = hexValue4;
//组合字符串
 PLC_date.Text = "20" + y1 + "年" + m1 + "月" + d1 + "日" + h1 + "时" + min1 + "分" + sec1 + "秒";
更多C#与PLC可以参看以下文章:
S7-200 Smart读取温湿度控制器,测试c#
C#通过modbus tcp与S7-200 smart通信测试
西门子S7-200smart设计设备间歇式控制,C#调试程序
