[西门子] C#记录S7-200 smart采集的温湿度到access
查看86 | 回复0 | 2024-11-21 07:49:00 | 显示全部楼层 |阅读模式
效果:
基于前面的程序
S7-200 Smart读取温湿度控制器,测试c#
增加一个按钮,链接access数据库,将数据定时记录到access数据库
 private void btn_connect_Click(object sender, EventArgs e)//连接数据库
     using (OleDbConnection connection = new OleDbConnection(connectionString))
         try
             connection.Open();
             MessageBox.Show("数据库连接成功");
             update_timer.Enabled = true;
             btn_connect.BackColor=Color.Green;
             btn_connect.Text = "数据库已连接";
             DateTime now = DateTime.Now;
             string dateString = now.ToString("yyyy-MM-dd HH:mm:ss");
             if (this.WD.Text == "")
                     MessageBox.Show("插入数据不能为空");
                 else
                     string reg = "insert into data(日期时间,温度,湿度) values('" + dateString + "','" + this.WD.Text + "','" + this.SD.Text + "')";
                     OleDbCommand cmd = new OleDbCommand(reg, connection);
                     cmd.CommandText = reg;
                     cmd.ExecuteNonQuery();
                     MessageBox.Show("数据添加成功");
         catch (Exception ex)
             MessageBox.Show("数据库连接失败" + ex.Message);
 private void timer2_Tick(object sender, EventArgs e)//定时插入数据库
         try
             connection.Open();
             else
