[西门子] C#与OPC通讯之数据读取
查看106 | 回复0 | 2024-11-21 07:47:04 | 显示全部楼层 |阅读模式
效果:
核心代码:
   private void startRead_Click(object sender, EventArgs e)
            if (this.startRead.Text=="开始读取")
                readmethod = (Readmethod)Enum.Parse(typeof(Readmethod), this.cmb_ReadMethod.Text, true);
                switch (readmethod)
                    case Readmethod.订阅读取:
                        Kepgroup.DataChange += Kepgroup_DataChange;
                        break;
                    default:
                        this.updateTimer.Enabled = true;
                        break;
                this.startRead.Text = "停止读取";
            else
                switch (readmethod)
                        Kepgroup.DataChange -= Kepgroup_DataChange;
                        break;
                    default:
                        this.updateTimer.Enabled =false;
                        break;
                this.startRead.Text = "开始读取";
//异步读取
 private void Kepgroup_AsyncReadComplete(int TransactionID, int NumItems, ref Array ClientHandles, ref Array ItemValues, ref Array Qualities, ref Array TimeStamps, ref Array Errors)
     for (int i = 1; i <= NumItems; i++)
         object value = ItemValues.GetValue(i);
         if (value != null)
             int clientHandle =Convert.ToInt32(ClientHandles.GetValue(i));
             var query = this.OPCVarList.Where(c => c.ClientHandle == clientHandle).FirstOrDefault();
             if (query != null)
                 query.OPCVaule = value.ToString();
                 query.OPCDataType = value.GetType().ToString();
                 query.OPCQuanlity = ((Array)Qualities).GetValue(i).ToString();
                 query.OPCUpdateTime = Convert.ToDateTime(((Array)TimeStamps).GetValue(i)).ToString();
     this.dataGridView1.DataSource = null;
     this.dataGridView1.DataSource = this.OPCVarList;
//订阅方式读取
private void Kepgroup_DataChange(int TransactionID, int NumItems, ref Array ClientHandles, ref Array ItemValues, ref Array Qualities, ref Array TimeStamps)
        if (value != null)
            int clientHandle = Convert.ToInt32(ClientHandles.GetValue(i));
            if (query != null)
