[西门子] C#与OPC链接测试
查看152 | 回复0 | 2024-11-21 07:48:43 | 显示全部楼层 |阅读模式
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Net;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using GodSharp.Opc.Da;
using OPCAutomation;//引用OPC驱动
namespace 泵站控制系统
    public partial class Form1 : Form
    public Form1()
            InitializeComponent();
            this.button1_Click(null,null);
        private void Form1_Load(object sender, EventArgs e)
            ServerNode.Text = "127.0.0.1";
        private OPCServer KepServer;
        #region 刷新节点
        private void button1_Click(object sender, EventArgs e)//刷新节点
            this.ServerNode.Items.Clear();
            string computerName = Environment.MachineName;
            IPHostEntry IPhost = Dns.GetHostEntry(System.Environment.MachineName);
            if (IPhost.AddressList.Length>0)
                for(int i=0;i<IPhost.AddressList.Length;i++)
                    // string Host = Dns.GetHostEntry(IPhost.AddressList).HostName;  //获取电脑主机名称
                    string Host = "localhost";
                    if (!this.ServerNode.Items.Contains(Host))
                        this.ServerNode.Items.Add(Host);
            #endregion
        #region 获取OPC列表
        private void ServerNode_SelectedIndexChanged(object sender, EventArgs e)
            if(KepServer==null)
                KepServer = new OPCServer();
    Object serverlist=KepServer.GetOPCServers(this.servername.Text);
            foreach(var item in (Array)serverlist)
                if (!this.servername.Items.Contains(item))
                    this.servername.Items.Add(item);
        #endregion
        #region 链接OPC
        private void button2_Click(object sender, EventArgs e)
            if (KepServer != null)//判断OPC是否存在
            try
                KepServer.Connect(this.servername.Text, this.ServerNode.Text);
                MessageBox.Show("连接成功");
            catch (Exception ex)
                MessageBox.Show("链接失败" + ex.Message);
                return;//连接失败,退出运行,后面代码不执行
            #endregion
