[西门子] 西门子PLC实现开关灯时间,C#设计测试系统
查看104 | 回复0 | 2024-11-21 07:48:30 | 显示全部楼层 |阅读模式
    因订阅号粉丝的要求,需要设计一个路灯时控程序,先抛砖引玉,用西门子S7-200 smart结合C#平台来演示。
     首先我们需要获得CPU的时钟:
利用READ_RTC来获得,需要初始化PLC的时钟
连接PLC后,读取PC时钟,然后点击设置。
此时我们可以监控年月日时分秒
在设置开关灯时间,
C#代码如下:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Drawing.Drawing2D;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using S7.Net;
namespace S7_200Smart路灯控制
    public partial class Form1 : Form
        public bool lamp1;
        public bool lamp2;
        Plc plc;//声明plc连接对象
        public string date_time;
        public Form1()
            InitializeComponent();
        private void Open_PLC_Click(object sender, EventArgs e)
            string Ip = txtIp.Text;//plcIp地址
            plc = new Plc(CpuType.S71200, Ip, 0, 1);//创建plc实例
            plc.Open();//连接plc
            if (plc.IsConnected)//检查plc是否连接上
                MessageBox.Show("与PLC连接成功!");
                timer1.Enabled = true;
                this.Read_set_data.PerformClick();
            else
                MessageBox.Show("与PLC连接失败!");
        private void Close_PLC_Click(object sender, EventArgs e)
            plc.Close();//断开PLC
        private void timer1_Tick(object sender, EventArgs e)
            date_time = DateTime.Now.ToString();
            if(lamp1)
                p2.Visible = true;
                p1.Visible = false;
            if (lamp2)
                p1.Visible = true;
                p2.Visible = false;
                this.Text = "路灯控制V1.0--PLC通讯已连接" + "   " + date_time + "  Designed by Honeytree";
            if (plc.IsConnected == false)
                this.Text = "路灯控制V1.0--PLC通讯未连接" + "   " + date_time + "  Designed by Honeytree";
                // MessageBox.Show("未连接PLC!", "连接提示", MessageBoxButtons.OK);
            else
                try
                    string y1;
                    string m1;
                    string d1;
                    string h1;
                    string min1;
                    string sec1;
                    //年
                    int intValue = ((byte)plc.Read("DB1.DBB0"));
                    string hexValue = intValue.ToString("X");
                    y1 = hexValue;
                    //月
                    int intValue1 = ((byte)plc.Read("DB1.DBB1"));
                    string hexValue1 = intValue1.ToString("X");
                    m1 = hexValue1;
                    //日
                    int intValue2 = ((byte)plc.Read("DB1.DBB2"));
                    string hexValue2 = intValue2.ToString("X");
                    d1 = hexValue2;
                    //时
                    int intValue5 = ((byte)plc.Read("DB1.DBB3"));
                    string hexValue5 = intValue5.ToString("X");
                    h1 = hexValue5;
                    byte v1 = byte.Parse(h1);
                    plc.Write("DB1.DBB200", v1);
                    //分
                    int intValue3 = ((byte)plc.Read("DB1.DBB4"));
                    string hexValue3 = intValue3.ToString("X");
                     min1 = hexValue3;
                    byte v2 = byte.Parse(min1);
                    plc.Write("DB1.DBB201", v2);
                    //秒
                    int intValue4 = ((byte)plc.Read("DB1.DBB5"));
                    string hexValue4 = intValue4.ToString("X");
                    sec1 = hexValue4;
                    PLC_date.Text = "20" + y1 + "年" + m1+"月" + d1+"日"  + h1 + "时" + min1 + "分" + sec1 + "秒";
                    //灯控
                    lamp1= ((bool)plc.Read("M0.0"));
                    lamp2 = ((bool)plc.Read("M0.1"));
                catch (Exception Ex)
                    MessageBox.Show("请检查输入的“地址”或“值”是否错误!" + Ex, "输入提示", MessageBoxButtons.OK);
        private void Set_ACK_Click(object sender, EventArgs e)
            else
                try
                    byte value = byte.Parse(start_hour.Text);
                   plc.Write("DB1.DBB20", value);
                     byte value1 = byte.Parse(stop_hour.Text);
                    plc.Write("DB1.DBB22", value1);
        private void Read_set_data_Click(object sender, EventArgs e)
           int hour1 = ((byte)plc.Read("DB1.DBB20"));
            start_hour.Text = hour1.ToString();
            int min1 = ((byte)plc.Read("DB1.DBB22"));
            stop_hour.Text = min1.ToString();
测试效果:
