PLC
1. PLC 可编程控制器
2. HMI 触摸屏
3. Encoder 编码器
4. step drive 步进
5. servo 伺服
6. servo motor 伺服电机
7. motor 电机
8. frequency converter 变频器
9. communication 通信
10.serial communication 串口通信
11.modbus communication :modbus通信
12.process field bus communication 现场总线通信
13.Ethernet communication 以太网通信
14.IPC 工控机
15.absolute 绝对
16.absoluteoutput 绝对最大输出
17.actuator 执行器
18.against 对比
19.allocate 分配
20.alter 改变 修改
21.ambient 环境 周围 ambient operating temperature
22.analog 模拟 analogoutput
23. analysis 分析 thecollection an and analysis of data
24. applicable 可用 the applicableCPU for the module
25.assign 分配
26.back up battey 备用电池
27.barcode reader/ID 条形码阅读器
28.base unit 主基板
29.baud rate 波特率
30. beforehand 事先
31 .binary 二进制
32.buffer memory 缓冲存储器
33. bus 总线
34. case 外壳 do notremove the module's print board from the case
35. characteristic 特征 I/Ocharacterristic
36. check 校验 the datalink status canbe checked
37. child-station 子站
38. common terminal 公共端
39. compatible 兼容 compatiblewith the MODBUS protocol
40. compound 混合 compoundsystem communication [`compaund]
41. condensation 结露
42. condition 条件 conditionsetting
43. conductive 导电 conductivemetal picees
44. configuration 组态 systemconfiguration
45. configure 组态
46. confirm 确认 how toconfirm the operation of the module
47. consumption 消耗 currentconsumption
48. content 目录
49. control level 控制级
50. convenient 方便 moreconvenient and easy-to-use
51. conventionaly 传统 whichconventionaly has been used
52. conversion 转换 Analog-Digital conversion module
53. converter 转换器
54. conveyor 传送 conveyorline
55. corrosive 腐蚀 corrosivegas
56. countermeasure 对策countermeasure for mis-inpute
57. cutoff 切断
58. debug 调试 isrecommended before debugging
59. dedicated 屏蔽 cc-linkdedicated cable
60. dedicated 专用 dedicatedtransmission protocol
61. default value 缺省值
62. define 解释 阐明 Offset value and gain value are defined as follow.
63. design 设计 design asystem
64. device level 现场级
65. diagnosis 诊断 diagnosisfunction
66. digital 数字 digitalinpute
67. DIN rail 导轨
68. diverse 不同的各种各样的
69. download 下载
70. duplicate 完全一样
71. dust 灰尘
72. eliminate 免得[i`limineit]
73. enterprise level 管理级
74. erase 清除
75. exceed 超出 The numberadmitted must not exceed 200
76. execute 执行 date linkis executed using these parameters
77. expand 扩展 can beeapanded up to 255 networks
78. faulty 故 障站
79. field bus 现场总线
80. fix 固定
81. flexibly 灵活的 to supporta variety systerm flexibly
82. flow 流量
83. format 格式transmission format [`fo:maet]
84. fuse 融丝,保险
85. graph 图标 坐标图曲线图 voltage output characterristicgraph
86. guaranteed 担保 nomaloperration cannot be guaranteed
87. handle 处理
88. hardware manual 硬件手册
89. hint 提示 programminghints
90. humidity 湿度 ambientoperating humdlity
91. individual 独立的
92. inductance 电感 inductanceload
93. initiate 实施 发起 can be initiate by a computer [i`nifieit]
94. input 输入
95. input point 输入点数
96. install 安装
97. instruction 指令 the FROMinstruction
98. insulation 隔离 form rubberprovides good insulation [,insju`leifn]
99. interface 接口
100. interlocking 互锁 can be usedfor sequence program interlocking
101. internal external 内部 外部 internal connection
102. interrupt 中断 excute aninterrupt processing
103. invalid 无效 errorinvalid station function
104. magnetic 有磁性的 magneticfields [maeg`netik]
105. main circuit 主回路
106. malfunction 故障 causesystem malfunction
107. mandatory 强制
108. mantenance 维护 maintenancecosts are reduced
109. manual 手册 User'Manual
110. mechanical 机械 michanicallife机械寿命
111. module 模块 mount orremove the module [`modju:l]
112. momentary power failure 瞬时断电
113. monitor 监视
114. mount 固定 mount orremove the module
115. multiple 多样 mutipleremote i/o modules
116. negative 负
117. observation 观察
118. occupy 占用 occupies 1station
119. occur 发生
120. offline 离线 offlinetest
121. offset gain 偏置增益
122. oil mist 油雾
123. optical loop 光缆回路
124. optimum 最佳的 optimumcontrol
125. output 输出
126. overall 总的 overalldistance
127. overview 总揽communication overview
128. parameter 参数
129. path 路径transmission path
130. per network
131. perform 进行 normal datalink cannot be performed
132. performance specifations 性能规格
133. peripheral 外围 Whenutilizing peripheral device to assign I/O number.
134. phase 相 swith offall phases of the power supply [`feiz]
135. point 要点
136. port 接口 Rs232c port
137. positive 正
138.power line 电源线
139. power on/off 上电断电
140. precaution 注意事项precaution when configuing system
141. print board 印刷电路板
142. procedure 过程 follow theprocedure
143. programing interface 编程口
144. protocol 协议 protocolcommunication issues
145. range 范围
146. rated input voltage 额定输入电压
147. ratio 比率
148. recommend 建议 isrecommended before debugging
149. reduce 减少 the numberof steps in operation program can be reduced
150. refer to 参照 refer toChapter 6
151. register 数据寄存器
152. relay 继电器 [`ri:lei]
153. remote I/O 远程网络
154. reserved station 预留主站
155. resistor 电阻 resistorload阻性负载 terminating resistor
156. resolution 分解,解析 nMaximum resolution 最大分辨率
157. restriction 限制 norestriction [ri`strikfn]
158. retry 重试
159. scan 扫描 link scan
160. screw 螺丝 Teminal-block screw
161. seamless network 无缝网络
162. sequence programme 顺控程序
163. serial communications module 串口模块
164. series 系列
165. servo 伺服
166. short 短路
167. signal 信号
168. sink 漏极 sink commen
169. slot 槽
170. soures 源极 sourescommen
171. specifications 特性 inputmodules specifications
172. stabilized power supply 稳压电源
173. standby master station 备用主站
174. start up 起动
175. status 状态 data linkstatus
176. step drive 步进驱动
177. storage 存储 storagearea
178. store 存储
179. switch off 关断 swith offall phases of the power supply
180. swith 开关
181. table 表格
182. transfer 传输
183. transistor 晶体管
184. transmission speed 传输速度
185. transmit 传送 data istransmitted in unchanged code
186. triac 双端三相可控硅开关
187. troubleshooting 故障处理
188. unuseble 不可以使用
189. upload 上传
190. utilize 利用 Whenutilizing peripheral device to assign I/O number.
191. verify 校验 verify theset parameter contents
192. voltage 电压 highvoltage
193. watchdog 看门狗
194. width 范围 it willvary in the width of [widθ]
195. wire chips 线头
工业机器人
1. robot 机器人
2. robot arms 机器人手臂
3. frame of axes 坐标系
4. joint 关节
5. USER 用户
6. WORLD 世界
7. TOOL 工具
8. Teach Pendant 示教器
9. Operate Panel 操作面板
10.Main Board 主板
11.Battery 电池
12.I/O Board:I/O板
13.E-Stop Unit 急停单元
14.Sero Amplifier 伺服放大器
15.Transformer 变压器
16.Fan Unit 风扇单元
17.Breaker 断路器
18.Regenerative Resistor 再生电阻
19.TCP 工具中心点 TOOL Center Point
20.Record 记录
21.Approach Point 接近点
22.X Direction Point X轴方向
23.Y Direction Point Y轴方向
24.Z Direction Point Z轴方向
25.Registers 寄存器
26.ACAS Applicator Cleaner Air Supply 雾化器清洗器供气
27.pACS Applicator Cleaner Solvent Pilot 雾化器清洗器溶剂控制阀
28.ACS Applicator Cleaner Solvent 雾化器清洗器溶剂
29.ACVA Applicator Cleaner Vacuum Air 雾化器清洗器真空空气
30.ACDA Applicator Cleaner Drying Air 雾化器清洗器干燥空气
31.BEAR Bearing Air 轴承空气
32.BAO Bearing Air OK 轴承空气正常
33.BRAKE Brake Air Turbine 涡轮刹车空气
34.PBW Bell Wash Pilot 旋杯清洗控制阀
34.BWS Bell Wash Supply 旋杯清洗供应
35.AIR Color Change Air Supply 换色空气供应
36.SOL Color Change Solvent Supply 换色溶剂供应
37.CP# Color Pilot (#) = Color 颜色控制阀(#)= 颜色
38.DUMP Dump 排放
39.DAT Drive Air Turbine 涡轮驱动空气
40.E-STAT Electrostatics 静电
41.pIW Injector Wash Pilot 注射器清洗控制阀
42.IWS Injector Wash Supply 注射器清洗供应
43.PAINT Paint 油漆
44.PAP Purge Air Pilot冲洗空气控制阀
45.PCC Pilot Color Change 换色控制阀
46.PCE Process Control Enclosure 工艺控制柜
47.PDUMP Pilot Dump 排放控制阀
48.PDP Power Distribution Panel 配电柜
49.PIE Process Interface Enclosure 工艺接口柜
50.PREG Pilot Regulator 调节器控制阀
51.PR# Paint Return (#) = Color 油漆回路(#)= 颜色
52.PS# Paint Supply (#) = Color 油漆进路(#)= 颜色
53.PPS Purge Solvent Pilot 冲洗溶剂控制阀
54.pTRIG Pilot Trigger 触发器控制阀
55.PTS Pilot Trigger Supply 触发器供应控制阀
56.RP Robot Purge 机器人净化
57.SA1 Shaping Air (Bell Applicator) 成形空气(旋杯雾化器)
58.SA2 Shaping Air (Bell Applicator) 成形空气(旋杯雾化器)
59.SAP Shaping Air Pilot 成形空气控制阀
60.SAS Shaping Air Supply 成形空气供气
61.SCC System Control Console 系统控制柜
62.TDP Turbine Drive Pilot (Bell Applicator) 涡轮驱动控制阀(旋杯雾化器)
63.TURB Turbine Drive Supply 涡轮驱动供气
64.Purge System Maintenance 净化系统维护
65.Purge System Diagnostics 净化系统诊断
66.Purge System Testing andCalibration 净化系统测试和校准
67.Purge Cycle Troubleshooting 净化循环排错
68.Color Changer Assembly 换色器组件
69.Color Changer Valve Maintenance 换色阀门维护
70.SolvAir Module Setup and Maintenance 溶剂空气模块设置和维护
71.3 Valve IK Gear Pump 3阀门1K齿轮泵
72.Pump Block Pressure Sensor 泵的压力传感器
73.Process Control Maintenance 工艺控制维护
74.Fluid Presets Maintenance 流体预设值维护
75.E-stat Presets Maintenance 静电预设值维护
76.Preset Override Maintenance 强制预设值维护
77.Color Change Maintenance 换色维护
78.Pepperl & Fuchs ISB Settings Pepperl & Fuchs ISB设置
79.Robot Software Maintenance 机器人软件维护
80.I/O Re-configuration I/O 重新配置
81.Robot File Copy 机器人文件复制
82.Robot System Variables Editing Transducer Operations 比例阀的操作
83.Shaping Air Control 成形空气的控制
84.D/Q Shaping Air Control Module D/Q 成形空气控制模块
85.Turbine Speed Control 涡轮速度控制
86.Keyence Digital Fiber Sensor Keyence 数字光线传感器
87.Fluid Calibration - Beaker Method流体校准量杯的方法
88.System Configuration Maintenance 系统配置维护
89.System Colors Maintenance 系统颜色维护
90.Styles Maintenance 车型维护
91.Option Maintenance 选项维护
92.PW3 Setup PW3 设置
93.Software Archive 软件存档
94.Backup a Robot Image 备份一个机器人镜像
95.Restore a Robot Image 恢复一个机器人镜像
96.Paintworks III Software Maintenance Paintworks III软件维护
97.Creating a Norton Ghost 2003 Boot Disk Set 创建一个98.Norton Ghost2003 启动盘
99.Backing Up Your PAINTworks III GUI 备份你的PAINTworksIII GUI
100.Copying Your Ghost Image Files to CDs 把你的Ghost 镜像文件复制到 CDs
101.Restoring Your PAINTworks III GUI 恢复你的PANITworks III GUI
102.PAIR PAP Pilot input for Purge Air 净化空气的驱动输入
103.PSOLV PSP Pilot input for Purge Solvent 净化溶剂的驱动输入
104.AIR CCAS Purge Air supply input 净化气源输入
105.SOL CCSS Purge Solvent supply input 净化溶剂供应输入
106.INJECTOR 注射器
107.WASH 清洗
108.PAINT ENABLE 喷漆激活
109.TRIGGER 触发器
110.BELL WASH 杯头清洗
111.PAINT 油漆
112.SOLV/AIR 溶剂/空气
113.AIR 空气
114.RECOVERY 回收
115.DUMP 排放
116.2K Process Assembly with a Regulator Schematic 含调整器的2K工艺组件示意图
117.BELL WASH 杯头清洗
118.CAT 架子
119.FLUSH 齐平
120.SOLV/AIR 溶剂/空气
121.SOL2 溶剂2
122.Applicator Interface 雾化器接口
123.FACE PLATE 面板
124.TOOL FRAME 工具架
125.EDGE OF BELL CUP 杯头边缘
126.SECTION A-A A-A截面
127.BRAKE 制动空气
128.PAINT 油漆管路
129.SPEED 速度
130.BEAR 轴承空气
131.SEAL 密封空气
132.TURB 涡轮空气
133.NOTES: 注意:
134.SECTION B-B B-B截面
135.SLOTTED CHEESE HEAD 槽形奶酪状顶部
136.MACHINE SCREW 加工螺丝
137.NYLON 6/6 30% SHORT 短的尼龙6/6 30%
138.FIBER GLASS FILLED 玻璃纤维填充
139.Torque to .55 Nm/4.8 In. Lbs. 转矩至.55 Nm/4.8 In. Lbs
140.Color Changer, Pump and Pump Block 换色器,泵和泵座
141.Solvent 溶剂
142.Solvent Supply Valve 溶剂供应阀门
143.Air Supply Valve 空气供应阀门
144.Solvent Wash Line 溶剂清洗管路
145.Pump Flush Valve 泵冲洗阀门
146.Dump Valve 2 排放阀门2
147.Bell Wash Valve 杯头清洗阀门
148.Injector Wash Valve 注射器清洗阀门
149.Trigger Valve 触发器阀门
150.Paint Enable Valve 喷漆激活阀门
151.Gear and Shaft Assembly 齿轮和轴体组件
152.Drive Shaft 驱动轴
153.Drive Gear 驱动齿轮
154.Key 销子
155.Rear Plate 后板体
156.Dowel (2) 销子(2) Arbor 柄轴
157.Driven Gear 驱动齿轮
158.Gear Plate 齿轮板
159.Front Plate 前板体
160.Seal 密封
161.Seal Housing 密封套
162.Purge Air 净化空气
163.Purge Solvent 净化溶剂
164.Pump Flush 泵冲洗
165.Enable 激活
166.Color Enable 激活颜色
167.Dump 2 排放2
168.Dump 排放
169. Injector Wash 注射器清洗
170.Paint Enable 喷漆激活
171.Bell Wash 杯体清洗
172.Trigger 触发器
173.Waste Recovery 废物回收
