[三菱] 亚控kingscada简单报表
查看79166 | 回复0 | 2024-5-14 14:17:59 | 显示全部楼层 |阅读模式
一、一览图
二、主要控件
2.1 日期控件:对象-->UI控件-->日期时间,本次设计两个日期时间,分别是UIDateTime1(查询开始日期)和UIDateTime2(查询结束日期);如下图所示:
2.2 报表控件:工具箱-->报表,定义为Report1
选择编辑后,出现可以编辑的表格:
2.3 按钮
2.3.1 查询按钮
按下脚本如下:
float y1;
float m1;
float d1;
long StartTime;
long EndTime;
y1=UIDateTime1.Year;
m1=UIDateTime1.Month;
d1=UIDateTime1.Day;
string dtime1=StrFromReal(y1,0,"f")+"-"+StrFromReal(m1,0,"f")+"-"+StrFromReal(d1,0,"f");
float y2;
float m2;
float d2;
long StartTime2;
long EndTime2;
y2=UIDateTime2.Year;
m2=UIDateTime2.Month;
d2=UIDateTime2.Day;
string dtime2=StrFromReal(y1,0,"f")+"-"+StrFromReal(m1,0,"f")+"-"+StrFromReal(d1,0,"f");
// \\local\selectdate=dtime1;
Report1.SetCellStrings(4,1,27,3,"");  //清空单元格
Report1.SetCellString(2,2,dtime1);  //填写日期
StartTime=ConvertTimeToSecond(y1,m1,d1,0,0,0,0);
EndTime=ConvertTimeToSecond(y2,m2,d2,23,59,59,0);
Report1.SetTime(StartTime,EndTime,3600000);
Report1.SetHistData("\\local\PV1",2);
Report1.SetHistData("\\local\PVQ1",3);
Report1.SetHistData("\\local\FT101",4);
Report1.SetHistData("\\local\Total_FT101",5);
Report1.SetHistData("\\local\JS_COD",6);
Report1.SetHistData("\\local\JS_进水NH3N",7);
Report1.Query();
2.3.2 打印预览按钮
Report1.Preview();
2.3.3 打印按钮
Report1.Print();
2.3.4 导出保存按钮
string filename;
filename="C:\进水报表.xls";
Report1.ReportSaveAs(filename);
