JZGKCHINA工控技术分享平台
1
General
FactoryTalk ViewPoint software, an add-on to FactoryTalk View Studio software, allows plant managers, production supervisors, system integrators, and other key stakeholders to view and control real-time plant floor operations remotely from a web browser. FactoryTalk ViewPoint enabled displays are fully scalable and animated in the browser. The remote user can also view displays that are not the active display of the terminal.
FactoryTalk ViewPoint 软件是 FactoryTalk View Studio 软件的附加组件,允许工厂经理、生产主管、系统集成商和其他主要利益相关者通过 Web 浏览器远程监控工厂的实时状态,并且画面在网页中可动态缩放。 Each PanelView Plus 6 - 700…1500 terminal contains one license that supports a single client connection to the terminal. No additional software is required. FactoryTalk ViewPoint software is not supported by the PanelView Plus 6 - 400 and 600 terminals.每一个PanelView Plus 6 700~1500系列终端包含一个但客户端的授权,不需要额外的软件。FactoryTalk ViewPoint软件不支持PanelView Plus 6 - 400 和 600终端。
Making your FactoryTalk View project accessible from a web browser or your favorite mobile device is quick and easy. Here’s how in 3 easy steps只需3步,轻松让你的FactoryTalk View项目接入浏览器或移动终端。
2
Create a new Machine Edition web
application 创建一个新的ME网页应用
2.1 In FactoryTalk View Studio, open the FactoryTalk View ME application that contains the displays you want to convert for the web.在FactoryTalk View Studio中,打开你的项目;2.2 Click Application > ViewPoint Administration to open FactoryTalk ViewPoint Administration.点击Application > ViewPoint Administration
2.3 In FactoryTalk ViewPoint Administration, click Publish Displays to Web, and then select and publish the displays.在FactoryTalk ViewPoint Administration中,点击Publish Displays to Web并选择想要发布的页面
Note:
Some of features and functions may not support in ME FactoryTalk ViewPoint applications
注意:有些功能在网页发布界面并不支持
2.4 Create the Machine Edition runtime application, and include FactoryTalk ViewPoint content.创建运行文件,并包含FactoryTalk ViewPoint内容
a. In FactoryTalk View Studio click Application > Create Runtime Application to create a runtime file (.mer). Select the Include ViewPoint Content check box located below the Type list. The check box is selected by default. The runtime file will provide the FactoryTalk View ME application and the published displays to the PanelView Plus terminal.在FactoryTalk View Studio中,点击Application > Create Runtime Application创建运行文件(.mer), 勾选Include ViewPoint Content(本项默认勾选);b. In Save as type, select the runtime version compatible with the firmware version of the targeted terminal.在Save as type 中,选择与目标终端相匹配的固件版本c. Click Save.
2.5 Download the Machine Edition runtime application to the PanelView Plus terminal that will host the web application.
下载运行文件
3
Connecting to an existing Machine
Edition web application 链接网页应用
Connect to a web application to view displays containing information about your plant or process.FactoryTalk ViewPoint for Machine Edition is limited to one connected session with one web browser window or tab. If all available licenses are in use, FactoryTalk ViewPoint shows the error, "There are no licenses currently available for the Web browser to use."连接到 网页应用以查看包含有关您的工厂或过程的信息的显示。FactoryTalk ViewPoint for Machine Edition 仅限于使用一个 Web 浏览器窗口或选项卡的一个连接会话。如果所有可用的许可证都在使用中,FactoryTalk ViewPoint 会显示错误,“当前没有可供 Web 浏览器使用的许可证。”3.1 Start a web browser.启动浏览器
3.2 In the browser's Address bar, enter the following URL, replacing computer_name_or_ip_address with the hostname or IP address of the PanelView Plus terminal:
在地址栏输入如下格式的网址http://computer_name_or_ip_address/FTVP
P.S.
1. Control(Write) function need additional setting in FactoryTalk ViewPoint Administration;
控制(写入)功能需要在FactoryTalk ViewPoint Administration页面中额外配置
2. HTTPS binding function also available;
HTTPS绑定功能同样支持
3. “Log on” function also available;
页面登录功能同样支持
4. For more details, please refer to the official documentation
更多详细信息请参照官方文档
作者简介
淡定齿轮:常驻伊拉克油田现场的工控人油气上游领域自动化过程控制从业多年
官方文档下载
下载地址:
https://share.weiyun.com/wZZM5tXK
加入剑指工控技术群,联系各群群管理员获得提取码。
未入群的工控友人
联系美女管理员入群
2023年5月
1.Smart200&V90伺服系统:已更新15课
2.贝加莱直播课程:已更新40课
3.EPLAN快速入门:已更新18课
4.剑指工控经典公开课:已更新22课5.新品推荐:已更新12课
6.专家课堂:已更新15课
