[西门子] 大全:S7-200 SMART系列模块接线原理图
查看34885 | 回复0 | 2024-3-22 08:25:54 | 显示全部楼层 |阅读模式
学技术,下资料
工控技术资料库
S7-200 SMART CPU模块接线图
(一)20系列
(1)CPU ST20 DC/DC/DC (6ES7 288-1ST20-0AA0)
(2)CPU SR20 AC/DC/Relay (6ES7 288-1SR20-0AA0)
(二)30系列
(1)CPU ST30 DC/DC/DC (6ES7 288-1ST30-0AA0)
(2)CPU SR30 AC/DC/Relay (6ES7 288-1SR30-0AA0)
(三)40系列
(1)CPU ST40 DC/DC/DC (6ES7 288-1ST40-0AA0)
(2)CPU SR40 AC/DC/Relay (6ES7 288-1SR40-0AA0)
(3)CPU CR40 AC/DC/Relay (6ES7 288-1CR40-0AA0)
(四)60系列
(1)CPU ST60 DC/DC/DC (6ES7 288-1ST60-0AA0)
(2)CPU SR60 AC/DC/Relay (6ES7 288-1SR60-0AA0)
(3)CPU CR60 AC/DC/Relay (6ES7 288-1CR60-0AA0)
S7-200 SMART EM模块接线图
(01)EM Digital 8 x Input (EM DE08)(6ES7 288-2DE08-0AA0)
(02)EM Digital 8 x Outputs (EM DT08)(6ES7 288-2DT08-0AA0)
(03)EM Digital 8 x Outputs Relay (EM DR08)(6ES7 288-2DR08-0AA0)
(04)EM Digital 8 x Inputs / Digital 8 x Outputs (EM DT16) (6ES7 288-2DT16-0AA0)
(05)EM Digital 8 x Inputs / Relay 8 x Outputs (EM DR16) (6ES7 288-2DR16-0AA0)
(06)EM Digital 16 x Inputs / Digital 16 x Outputs (EM DT32) (6ES7 288-2DT32-0AA0)
(07)EM Digital 16 x Inputs / Relay 16 x Outputs (EM DR32) (6ES7 288-2DR32-0AA0)
(08)EM Analog 4 x Inputs (EM AE04) (6ES7 288-3AE04-0AA0)
(09)EM Analog 8 x Inputs (EM AE08) (6ES7 288-3AE08-0AA0)
(10)EM Analog 2 x Outputs (EM AQ02)(6ES7 288-3AQ02-0AA0)
(11)EM Analog 4 x Outputs (EM AQ04)(6ES7 288-3AQ04-0AA0)
(12)EM Analog 2 x Inputs / Analog 1 x Outputs (EM AM03) (6ES7 288-3AM03-0AA0)
(13)EM Analog 4 x Inputs / Analog 2 x Outputs (EM AM06) (6ES7 288-3AM06-0AA0)
(14)EM RTD 2 x 16 bit (EM AR02)(6ES7 288-3AR02-0AA0)
(15)EM RTD 4 x 16 bit (EM AR04)(6ES7 288-3AR04-0AA0)
(16)EM TC 4 x 16 bit (EM AT04) (6ES7 288-3AT04-0AA0)
(17)SE Analog 1 x Input (SB AE01)(6ES7 288-5AE01-0AA0)
(18)SB Analog 1 x Output (SB AQ01)(6ES7 288-5AQ01-0AA0)
(19)SB Digital 2 x Input / Digital 2 x Outputs(SB DT04) (6ES7 288-5DT04-0AA0)
(20)SB RS485/RS232 (SB CM01)(6ES7 288-5CM01-0AA0)
【延伸阅读】
大全:西门子S7-300系列模块接线原理图
大全:西门子S7-200系列模块接线原理图
资料口令:1010301
资料名称:S7-200 SMART CAD图库
