siemens 300/400编程技巧3则
S7 300400 的一些功能和技巧1
数据块拷贝 FUNCTION FC 100 : VOID TITLE = //DB BLOCK COPY AUTHOR : AXG NAME : DBBTODBB VERSION : 0.1
VAR_INPUT SOU_DB : INT ; //SOURCE DB NUMBER LENG : INT ; //HOW MANY TO COPY DES_DB : INT ; //DESTINATION DB NUMBER END_VAR VAR_TEMP SOURCE : ANY ; DEST : ANY ; END_VAR BEGIN NETWORK TITLE =
LAR1 P##SOURCE; // Load the start address of the ANY pointers in AR1. L B#16#10; // Load the syntax ID and T LB [AR1,P#0.0]; // transfer it to the ANY pointer. L B#16#4; // Load data type WORD and T LB [AR1,P#1.0]; // transfer it to the ANY pointer. L #LENG; // Load HOW MANY WORDS and T LW [AR1,P#2.0]; // transfer them to the ANY pointer L #SOU_DB; // Source is DB[?], DBB0.0 T LW [AR1,P#4.0]; // L P#DBX 0.0; // T LD [AR1,P#6.0]; // LAR1 P##DEST; //Load the DESTINATION address of the ANY pointer in AR1. L B#16#10; //Load the syntax ID and T LB [AR1,P#0.0]; //transfer it to the ANY pointer. L B#16#4; //Load data type WORD and T LB [AR1,P#1.0]; //transfer it to the ANY pointer. L #LENG; //Load HOW MANY WORDS and T LW [AR1,P#2.0]; //transfer them to the ANY pointer. L #DES_DB; //Destination is DB{?}, DBB0.0 T LW [AR1,P#4.0]; L P#DBX 0.0; // T LD [AR1,P#6.0]; // CALL "BLKMOV" (//Call the block move system function SRCBLK := #SOURCE,// RET_VAL := MW 210,//Evaluate the BR bit and MW 210 DSTBLK := #DEST);//
END_FUNCTION
使用说明:可直接调用,#SOURCE---源数据块号 #DEST------目标数据块号 #LENG----要拷贝数据的长度
