?? 在CONCEPT的模拟调试中,模拟量输入现在没有信号,可以象开关量一样进行强制吗?我觉得应该有这种功能,但不知道怎么设置,求助各位!!! ????1 From the main menu, select Online and then the Reference data editor menu command. 2 Enter the variables to be displayed in the dialog box marked RDE Templates. 3 To set the value highlight the Disable check box, and enter the desired value. 4 The RDE template can be saved under a unique name. To do this, invoke the RDE main menu option and select the Save template as… menu command. Note: Several RDE templates can be invoked at once. To do this, invoke the RDE main menu option and select the Open template... menu command. ????老大,不行啊,在RDE Template中模拟量的Disable不能设置,是暗的, ????在模拟器上就可以调整啊:plc32.exe ????to 昨日重现, 模拟量的调整,与Disable是无关的 ????谢谢各位,我在试下看,但我记得用模拟器时PC是不能和PLC建立连接的,我记错了吗?? ????用模拟器就是模拟PLC啊,模拟器与CONCEPT之间用MODBUS TCP通信,在RDE中是不可以改变模拟量输入(3开头)的值的! & .....查看全部
