189个PLC常用英语
1. PLC 可编程逻辑控制器
2. absolute 绝对位置
3. absoluteoutput 绝对输出
4 .actuator 执行器/作动器
5. against 对比
6. allocate 分配
7. alter 改变/修改
8. ambient 环境周围 ambient operating temperature
9. analog 模拟 analogoutput
10. analysis  分析  thecollection an and analysis of data
11. wire chips 线头
12. applicable 可用 the applicableCPU for the module
13. assign 分配
14. back up battey 备用电池
15. barcode reader/ID 条形码阅读器
16. base unit 主基板
17. baud 波特
18. beforehand 事先
19. binary 二进制
20. buffer memory 缓冲存储器
21. bus 总线
22. case 外壳 do notremove the module's print board from the case
23. characteristic  特征I/Ocharacterristic
24. check 校验 the datalink status canbe checked
25. child-station 子站
26. common terminal 公共端
27. compatible 兼容 compatiblewith the MODBUS protocol
28. compound 混合 compoundsystem communication
29. condensation 结露
30. condition 条件 conditionsetting
31.conductive 导电 conductivemetal picees
32. configuration  组态systemconfiguration
33. configure 组态
34. confirm 确认how toconfirm the operation of the module
35.consumption  消耗currentconsumption
36. content 目录
37. control level 控制级
38. convenient 方便 moreconvenient and easy-to-use
39.conventionaly  传统whichconventionaly has been used
40. conversion 转换 Analog-Digital conversion module
41. converter 转换器
42. conveyor  传送  conveyorline
43. corrosive 腐蚀 corrosivegas
44. countermeasure  对策countermeasure for mis-inpute
45. cutoff 切断
46. debug 调试 isrecommended before debugging
47. dedicated  屏蔽cc-linkdedicated cable
48.dedicated 专用 dedicatedtransmission protocol
49. default value 缺省值
50. define 解释/阐明 Offset value and gain value are defined as follow.
51. design 设计 design asystem
52. device level 现场级
53. diagnosis 诊断 diagnosisfunction
54. digital 数字 digitalinpute
55. DIN rail 导轨
56. diverse 不同的/各种各样的
57. download 下载
58. duplicate 完全一样
59. dust 灰尘
60. eliminate 免得
61. enterprise level 管理级
62. erase 清除
63. exceed 超出The numberadmitted must not exceed 200
64.execute 执行date linkis executed using these parameters
65. expand 扩展 can beeapanded up to 255 networks
66. faulty 故障站
67. field bus 现场总线
68. fix 固定
69. flexibly 灵活的 to supporta variety systerm flexibly
70. flow 流量
71. format 格式 transmission format
72. fuse 融丝
73.graph图标坐标图曲线voltage output characterristicgraph
74.guaranteed 担保nomaloperration cannot be guaranteed
75. handle 处理
76. hardware manual 硬件手册
77. hint 提示 programminghints
78. humidity 湿度 ambientoperating humdlity
79. individual 独立的
80. inductance 电感 inductanceload
81. initiate 实施发起 can be initiate by a computer [i`nifieit]
82. input 输入
83. input point 输入点数
84. install 安装
85. instruction 指令
the FROMinstruction
86. insulation 隔离 form rubberprovides good insulation
87. interface 接口
88.interlocking 互锁can be usedfor sequence program interlocking
89. internal external 内部 外部 internal connection
90. interrupt 中断 excute aninterrupt processing
91. invalid 无效 errorinvalid station function
92. magnetic 有磁性的 magneticfields [maeg`netik]
93. main circuit 主回路/线电路
94. malfunction 故障 causesystem malfunction
95. mandatory 强制
96. mantenance  维护maintenancecosts are reduced
97. manual 手册 User'Manual
98. mechanical 机械 michanicallife 机械寿命
99. module 模块/组件 mount orremove the module
100. momentary power failure 瞬时断电
101. monitor 监视
102. mount 固定 mount orremove the module
103. multiple 多样 mutipleremote i/o modules
104. negative 负
105. observation 观察
106. occupy 占用 occupies 1station
107. occur 发生
108. offline 离线 offlinetest
109. offset gain 偏置增益
110. oil mist 油雾
112. optical loop 光缆回路
113. optimum 最佳的 optimumcontrol
114. output 输出
115. overall 总的 overalldistance
116. overview 总揽 communication overview
117. parameter 参数
118. path 路径 transmission path
119. per network
120. perform 进行 normal datalink cannot be performed
121. performance specifations 性能规格
122. peripheral 外围/外部设备 Whenutilizing peripheral device to assign I/O number.
123. phase 相 swith offall phases of the power supply
124. point 要点
125. port 接口 Rs232c port
126. positive 正
127.power line 电源线
128. power on/off 电源开/关
129.precaution 注意事项precaution when configuing system
130. print board 印刷电路板
131. procedure  过程follow theprocedure
132. programing interface 编程接口/编程界面
133. protocol  协议protocolcommunication issues
134. range 范围
135. rated input voltage 额定输入电压
136. ratio 比率
137. recommend 建议 isrecommended before debugging
138. reduce 减少/缩小 the numberof steps in operation program can be reduced
139. refer to 参照 refer toChapter 6
140. register 数据寄存器
141. relay 继电器
142. remote I/O 远程网络
143. reserved station 预留主站
144. resistor 电阻器
145.load bridgingresistor  负载转移电阻
146.load compensating resistor 负荷补偿电阻
147.load shifting resistor 负载移动电阻器 ; 负荷转移电阻
148.load-resistor contactor 负载电阻器接触器 ; 负荷电阻接触器
149.anode load resistor 释义阳极负载电阻 ; 阳极负载电阻
150.effect of load resistor  负载电阻效应
151. resolution  分辨率nMaximum resolution  最大分辨率
152. restriction 限制 norestriction [ri`strikfn]
153. retry 重试
154. scan 扫描 link scan
155. screw 螺丝 Teminal-block screw
156. seamless network 无缝网络
157. sequence programme 顺控程序
158. serial communications module 串口通信模块
159. series 系列
160. servo 伺服系统
161. short 短路
162. signal 信号
163. sink 漏极 sink commen
164. slot 周边元件扩展插槽
165. soures 源极 sourescommen
166. specifications 特性 inputmodules specifications
167. stabilized power supply 稳压电源
168. standby master station 备用主站
169. start up 起动
170. status 状态 data linkstatus
171. step drive 步进
172. storage 存储 storagearea
173. store 存储
174. switch off 切断 swith offall phases of the power supply
175. swith 开关
176. table 表格
177. transfer 传送
178. transistor 晶体管
179. transmission speed 传输速度
180. transmit 传送/传输 data istransmitted in unchanged code
181. triac 三端双向可控硅开关元件
182. troubleshooting 故障处理
183. unuseble 不可以使用
184. upload 上传/上载
185. utilize 利用
186. verify 校验 verify theset parameter contents
187. voltage 电压 highvoltage
188. watchdog 看门狗定时器
189. width 范围
