此代码主要供系列文章:
《入门项目【自动打螺丝机】C#、PLC、触摸屏实战》学习使用。
using System;
using System.Collections.Generic;
using System.IO.Ports;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace CcrewMachine
    /// 基恩士扫码枪串口通讯类
    internal class KeyenceScan
        // 串口状态标识
        public bool IsOpened;                  // 记录串口是否打开
        public SerialPort SerialPort;          // 串口对象
        public int SerialPortSendCount;        // 串口发送次数
        public string BufferString;            // 接收到的字符串
        public string OpenScanCommand = "LON\r\n";   // 开启扫描命令
        public string CloseScanCommand = "LOFF\r\n"// 关闭扫描命令
        /// 构造函数
        /// 串口数据接收事件处理器
        public KeyenceScan(SerialDataReceivedEventHandler dataReceivedHandler)
            SerialPort = new SerialPort();
            SerialPort.DataReceived += dataReceivedHandler;
            IsOpened = false;
            SerialPortSendCount = 0;
            BufferString = "";
        /// 初始化串口
        /// 串口号
        /// 波特率
        /// 校验位
        /// 数据位
        /// 停止位
        /// 初始化成功返回true,失败返回false
        public bool Initialize(string comPort, int baudRate, Parity parity, int dataBits, StopBits stopBit)
            try
                IsOpened = false;
                SerialPort.PortName = comPort;
                SerialPort.BaudRate = baudRate;
                SerialPort.Parity = parity;
                SerialPort.DataBits = dataBits;
                SerialPort.StopBits = stopBit;
                SerialPort.ReceivedBytesThreshold = 1;
                SerialPort.ReadTimeout = 1000;
                SerialPort.Open();
                BufferString = "";
                IsOpened = true;
            catch (Exception)
                return false;
            return true;
        /// 检查接收数据是否有效
        /// 有效返回true,无效返回false
        public bool CheckData()
            bool result = false;
            do
                if (BufferString[0] == 0x15)
                    // 写入错误
                    break;
                result = true;
            } while (false);
            return result;
        /// 发送开启扫描命令
        /// 发送成功返回true,失败返回false
        public bool OpenScan()
            try
                SerialPort.Write(OpenScanCommand);
            catch (Exception)
                return false;
            return true;
        /// 发送关闭扫描命令
        public bool CloseScan()
            try
                SerialPort.Write(CloseScanCommand);
            catch (Exception)
                return false;
            return true;
        /// 读取串口接收的所有数据
        /// 0表示接收完成,-1表示未完成或失败
        public int ReadExisting()
            int returnValue = -1;
            do
                if (SerialPort.IsOpen)
                    BufferString += SerialPort.ReadExisting();
                    // 判断回车结束
                    if (BufferString.Length > 1)
                        // 转换字节判断末尾是否为回车
                        byte[] byteBuffer = System.Text.Encoding.Default.GetBytes(BufferString);
                        if (byteBuffer[byteBuffer.Length - 1] == 0x0D)
                            // 接收结束,移除末尾回车
                            BufferString = BufferString.Remove(BufferString.Length - 1);
                            returnValue = 0;
                        else
                            break;
                    else
                        break;
                else
                    BufferString = "";
                    break;
            } while (false);
            return returnValue;
        /// 关闭串口
        public void Close()
                try
                    IsOpened = false;
                    SerialPort.Close();
                catch (Exception)
                    // 忽略关闭异常
