用BC++编写的带PIC-SERVO CMC运动控制器的3轴钻床控制器和G代码解释程序
查看3875 | 回复13 | 2009-4-29 21:13:00 | 显示全部楼层 |阅读模式
[replyview]对G码的解析、对刀路进行算法修正、对硬件接口的控制、在显示界面上的进行友好的图形展示。
Borland's C++ Builder
PIC-SERVO CNC (PSCNC) is a complete example program for operating a 3-axis milling machine.
It runs under Windows 95/98/NT/2000 and interfaces to three PIC-SERVO CMC (coordinated
motion control) servo motor controllers. It includes the following features:
· Digital position readout panel displays positions in program or raw machine coordinates
· Controls for setting the origin of the program coordinate system
· Servo disable controls allows the use of hand cranks while still displaying the position
· Manual jogging controls
· G-Code Display window and immediate single-line G-Code execution
· Dynamic feed rate override, rapid speed override
· Continuous contouring of tangent and near tangent tool path segments
· Tool length compensation
The G-Code interpreter only implements a basic set G-Codes and M-Codes, but should be
sufficient in-depth evaluation purposes. The source
[replyview]
[upload=zip,pscnc.zip]viewFile.asp?ID=4856[/upload]
[/replyview]
[此贴子已经被作者于2009-5-3 22:04:47编辑过]
daisylee | 2009-7-2 06:16:00 | 显示全部楼层
gdfgdf
pcx1668 | 2009-7-25 21:59:00 | 显示全部楼层
好东西学习下
haamn | 2009-8-8 14:43:00 | 显示全部楼层
看看
haiyang051 | 2009-8-22 06:18:00 | 显示全部楼层
真的需要学习,谢谢!
wdzbcy | 2009-10-25 23:27:00 | 显示全部楼层
学习一下。谢谢!
wlxboss | 2009-11-6 00:11:00 | 显示全部楼层
看看,学习学习,谢谢。
lxiang1208 | 2009-11-19 08:44:00 | 显示全部楼层
很想学习学习
xuelongpcb | 2009-11-25 09:17:00 | 显示全部楼层
看看
jamspider | 2009-12-29 23:56:00 | 显示全部楼层
好东西学习下
vtlianggl | 2011-12-31 10:44:00 | 显示全部楼层
学习
yulin3192 | 2013-1-22 19:21:12 | 显示全部楼层
谢谢了
有更详细的资料吗
zxd0800 | 2013-2-20 14:18:12 | 显示全部楼层
能够提供他们专有库函数的说明吗?例如PATHLIB4.dll
冰雪爱肖 | 2014-8-30 08:00:59 | 显示全部楼层
你加油吧!!!
有她没她毁他日久生情代替他陪着她  ||  有他没他想他人生漫漫爱着他念着他
普林艾尔  http://www.preair.cn小店出售各类空气处理设备,淘宝店铺搜索“方凌电器”就可以找到。
