 找回密码
QQ登录
查看: 2485|回复: 7
三菱PLC编程口通信C语言源代码
发表于 2008-12-11 23:51:00 | 显示全部楼层 |阅读模式
fxnew.h
#define DELAY_TIMES 30000L
#define TRUE 1
#define FALSE 0
#define TRUE 1
#define FALSE 0
#define FORCE_ON 0x37
#define FORCE_OFF 0x38
void init_plc(void);
int check_plc(void);
int _read_data_register(unsigned int uAddress,unsigned int number);
int _read_mdata_register(unsigned int uAddress,unsigned int number);
int _write_data_register(unsigned int uAddress,unsigned int number);
int _force_m_contact(unsigned int uAddress,unsigned char ucOn_off);
int read_data_register(unsigned int uAddress,unsigned int number);
int read_mdata_register(unsigned int uAddress,unsigned int number);
int write_data_register(unsigned int uAddress,unsigned int number);
int force_m_contact(unsigned int uAddress,unsigned char ucOn_off);
int _read_m_register(unsigned int uAddress,unsigned int number);
int read_m_register(unsigned int uAddress,unsigned int number);
int TESTING=0;
unsigned int uRead_value[25];
unsigned int uWrite_value[25];
unsigned int COMM_PORT=1;
unsigned int STATS_PORT=0x2fd;
unsigned int DATA_PORT=0x2f8;
void init_plc(void)
{ _AX=0xfa;
_DX=COMM_PORT;
geninterrupt(0x14);
while((inportb(STATS_PORT)&1)!=0)inportb(DATA_PORT);
int check_plc(void)
{ long lTmp;
if(TESTING==1)return TRUE;
init_plc();
for(lTmp=0L;lTmp<DELAY_TIMES;lTmp++)
{ if((inportb(STATS_PORT)&0x20)!=0)
break;
if(lTmp>=DELAY_TIMES)
return(FALSE);
outportb(DATA_PORT,5);
disable();
{ if((inportb(STATS_PORT)&1)!=0)
break;
{ enable();
return(FALSE);
if((lTmp=inportb(DATA_PORT))==6)
{ enable();
return(TRUE);
else
{ enable();
return(FALSE);
{ int i;
for(i=0;i<3;i++)
if(_read_data_register(uAddress,number)==TRUE)
return TRUE;
return FALSE;
{ unsigned char uSend[]={2,0x30,0x30,0x30,0x30,0x30,0x30,0x32,3,0x30,0x30};
unsigned char uReceive[104];
unsigned int uTmp;
unsigned int uSum;
unsigned int num;
long lTmp;
int i,j;
if(TESTING==1)
{ for(i=0;i<number;i++)uRead_value=0;
return TRUE;
init_plc();
num=number*2;
if((num/16)>=10)
uSend[6]=(unsigned char)(num/16+0x41-10);
else
uSend[6]=(unsigned char)(num/16+0x30);
if((num%16)>=10)
uSend[7]=(unsigned char)((num%16)+0x41-10);
else
uSend[7]=(unsigned char)((num%16)+0x30);
uAddress=uAddress*2+0x1000;
uTmp=uAddress & 0x000f;
uSend[5]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
uTmp=(uAddress>>4) & 0x000f;
uSend[4]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
uTmp=(uAddress>>8) & 0x000f;
uSend[3]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
uTmp=(uAddress>>12)&0x000f;
uSend[2]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
uSum=0;
for(i=1;i<9;i++)
uSum=uSum+(unsigned char)uSend;
uTmp=uSum&0x000f;
uSend[10]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
uTmp=(uSum>>4)&0x000f;
uSend[9]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
for(i=0;i<11;i++)
{ for(lTmp=0L;lTmp<DELAY_TIMES;lTmp++)
break;
return(FALSE);
outportb(DATA_PORT,uSend);
disable();
for(lTmp=0;lTmp<DELAY_TIMES;lTmp++)
break;
enable();
return(FALSE);
uReceive[0]=inportb(DATA_PORT);
if(uReceive[0]!=2)
enable();
return(FALSE);
for(i=1;i<number*4+4;i++)
break;
enable();
return(FALSE);
uReceive=inportb(DATA_PORT);
enable();
uSum=0;
for(i=1;i<number*4+2;i++)
uSum=uSum+(unsigned int)uReceive;
uTmp=uSum&0xf;
uTmp=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
if((unsigned char)uTmp!=uReceive[number*4+3])return(FALSE);
uTmp=(uSum>>4)&0xf;
if((unsigned char)uTmp!=uReceive[number*4+2])return(FALSE);
for(j=0;j<number;j++)
{ for(i=j*4+1;i<j*4+5;i++)
uReceive=(uReceive>0x39)?uReceive-0x41+0xa:uReceive-0x30;
uRead_value[j]=(((((uReceive[j*4+3]<<4)+uReceive[j*4+4])<<4)+uReceive[j*4+1])<<4)+uReceive[j*4+2];
return TRUE;
{ int i;
for(i=0;i<3;i++)
if(_read_mdata_register(uAddress,number)==TRUE)
return TRUE;
return FALSE;
unsigned int uTmp;
unsigned int uSum;
unsigned int num;
long lTmp;
int i,j;
if(TESTING==1)
return TRUE;
init_plc();
num=number*2;
if((num/16)>=10)
else
if((num%16)>=10)
else
/*uAddress=uAddress*2+0x1000;*/
uSum=0;
for(i=1;i<9;i++)
uTmp=uSum&0x000f;
for(i=0;i<11;i++)
break;
return(FALSE);
disable();
break;
enable();
return(FALSE);
if(uReceive[0]!=2)
enable();
return(FALSE);
break;
enable();
return(FALSE);
enable();
uSum=0;
uTmp=uSum&0xf;
uTmp=(uSum>>4)&0xf;
return TRUE;
{ int i;
for(i=0;i<3;i++)
if(_write_data_register(uAddress,number)==TRUE)
return TRUE;
return FALSE;
{ unsigned char uSend[111];
unsigned int uTmp,uSum,num;
long lTmp;
int i;
init_plc();
uSend[0]=2;
uSend[1]=0x31;
uSend[number*4+8]=3;
num=(number*2)/16;
if(num>=10)uSend[6]=num+0x41-10;
else uSend[6]=num+0x30;
num=(number*2)%16;
if(num>=10)uSend[7]=num+0x41-10;
else uSend[7]=num+0x30;
uAddress=0x1000+2*uAddress;
uTmp=uAddress&0x000f;
uTmp=(uAddress>>4)&0x000f;
uTmp=(uAddress>>8)&0x000f;
uTmp=uWrite_value&0x000f;
uSend[i*4+9]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
uTmp=(uWrite_value>>4)&0x000f;
uSend[i*4+8]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
uTmp=(uWrite_value>>8)&0x000f;
uSend[i*4+11]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
uTmp=(uWrite_value>>12)&0x000f;
uSend[i*4+10]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
uSum=0;
for(i=1;i<9+number*4;i++)
uSum+=uSend;
uTmp=uSum&0x000f;
uSend[number*4+10]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
uSend[number*4+9]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
for(i=0;i<11+number*4;i++)
break;
/*enable();*/
return(FALSE);
disable();
break;
enable();
return(FALSE);
if(inportb(DATA_PORT)!=6)
enable();
return(FALSE);
else
enable();
return(TRUE);
int force_m_contact(unsigned uAddress,unsigned char ucOn_off)
{ int i;
for(i=0;i<3;i++)
if(_force_m_contact(uAddress,ucOn_off)==TRUE)
return TRUE;
return FALSE;
int _force_m_contact(unsigned uAddress,unsigned char ucOn_off)
{ unsigned uSend[]={2,0x37,0x30,0x30,0x30,0x30,3,0x30,0x30};
unsigned uTmp,uSum,i;
long lTmp;
init_plc();
uAddress=uAddress+0x800;
uSend[1]=ucOn_off;
uSum=0;
for(i=1;i<7;i++)
uSum+=uSend;
uTmp=uSum&0x000f;
uSend[8]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
uSend[7]=(uTmp<10)?(uTmp+0x30):(uTmp+0x41-0xa);
for(i=0;i<9;i++)
break;
enable();
return(FALSE);
disable();
break;
enable();
return(FALSE);
enable();
return(FALSE);
else
{ enable();
return(TRUE);
{ int i;
for(i=0;i<3;i++)
if(_read_m_register(uAddress,number)==TRUE)
return TRUE;
return FALSE;
unsigned char uReceive[54];
unsigned int uTmp;
unsigned int uSum;
unsigned int num;
long lTmp;
int i,j;
if(TESTING==1)
return TRUE;
init_plc();
num=number;
if((num/16)>=10)
else
if((num%16)>=10)
else
uAddress=uAddress/8+0x100;
uSum=0;
for(i=1;i<9;i++)
uTmp=uSum&0x000f;
for(i=0;i<11;i++)
break;
/*enable();*/
return(FALSE);
disable();
break;
enable();
return(FALSE);
if(uReceive[0]!=2)
enable();
return(FALSE);
for(i=1;i<number*2+4;i++)
break;
enable();
return(FALSE);
enable();
uSum=0;
for(i=1;i<number*2+2;i++)
uTmp=uSum&0xf;
if((unsigned char)uTmp!=uReceive[number*2+3])return(FALSE);
uTmp=(uSum>>4)&0xf;
if((unsigned char)uTmp!=uReceive[number*2+2])return(FALSE);
{ for(i=j*2+1;i<j*2+3;i++)
uRead_value[j]=((uReceive[j*2+1])<<4)+uReceive[j*2+2];
return TRUE;
使用道具 举报
发表于 2008-12-12 16:27:00 | 显示全部楼层
不明
回复 支持 反对
使用道具 举报
发表于 2009-1-10 21:13:00 | 显示全部楼层
看不明白
回复 支持 反对
使用道具 举报
发表于 2009-5-9 19:26:00 | 显示全部楼层
对程序结构和数据结构作一些简略说明,就更好了.
回复 支持 反对
使用道具 举报
发表于 2009-6-18 14:26:00 | 显示全部楼层
看不懂
回复 支持 反对
使用道具 举报
发表于 2009-7-21 10:41:00 | 显示全部楼层
谢谢,楼主的无私奉献!这种贴我喜欢~!~顶
回复 支持 反对
使用道具 举报
发表于 2009-7-21 10:42:00 | 显示全部楼层
当然,我也顺带赚点钱了~!~
回复 支持 反对
使用道具 举报
发表于 2010-1-23 13:10:00 | 显示全部楼层
学习了,谢谢
回复 支持 反对
使用道具 举报
GMT+8, 2024-9-20 17:52 , Processed in 0.049313 second(s), 25 queries .
快速回复 返回顶部 返回列表
