C语言库函数大全及应用实例三
查看2537 | 回复3 | 2006-8-24 09:40:00 | 显示全部楼层 |阅读模式
C语言库函数大全及应用实例三
函数名: ecvt
功 能: 把一个浮点数转换为字符串
用 法: char ecvt(double value, int ndigit, int *decpt, int *sign);
程序例:
#i nclude
#i nclude
#i nclude
int main(void)
char *string;
double value;
int dec, sign;
int ndig = 10;
clrscr();
value = 9.876;
string = ecvt(value, ndig, &dec, &sign);
printf("string = %s dec = %d \
sign = %d\n", string, dec, sign);
value = -123.45;
ndig= 15;
string = ecvt(value,ndig,&dec,&sign);
printf("string = %s dec = %d sign = %d\n",
string, dec, sign);
value = 0.6789e5; /* scientific
notation */
ndig = 5;
printf("string = %s dec = %d\
return 0;
函数名: ellipse
功 能: 画一椭圆
用 法: void far ellipse(int x, int y, int stangle, int endangle,
int xradius, int yradius);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
/* request auto detection */
int gdriver = DETECT, gmode, errorcode;
int midx, midy;
int stangle = 0, endangle = 360;
int xradius = 100, yradius = 50;
/* initialize graphics, local variables */
initgraph(&gdriver, &gmode, "");
/* read result of initialization */
errorcode = graphresult();
if (errorcode != grOk)
/* an error occurred */
printf("Graphics error: %s\n",
grapherrormsg(errorcode));
printf("Press any key to halt:");
getch();
exit(1);
/* terminate with an error code */
midx = getmaxx() / 2;
midy = getmaxy() / 2;
setcolor(getmaxcolor());
/* draw ellipse */
ellipse(midx, midy, stangle, endangle,
xradius, yradius);
/* clean up */
getch();
closegraph();
return 0;
函数名: enable
功 能: 开放硬件中断
用 法: void enable(void);
程序例:
/* ** NOTE:
This is an interrupt service routine. You can NOT compile this program
with Test Stack Overflow turned on and get an executable file which will
operate correctly.
#i nclude
#i nclude
#i nclude
/* The clock tick interrupt */
#define INTR 0X1C
void interrupt ( *oldhandler)(void);
int count=0;
void interrupt handler(void)
disable interrupts during the handling of the interrupt
disable();
/* increase the global counter */
count++;
re enable interrupts at the end of the handler
enable();
/* call the old routine */
oldhandler();
int main(void)
/* save the old interrupt vector */
oldhandler = getvect(INTR);
/* install the new interrupt handler */
setvect(INTR, handler);
/* loop until the counter exceeds 20 */
while (count < 20)
printf("count is %d\n",count);
/* reset the old interrupt handler */
setvect(INTR, oldhandler);
return 0;
函数名: eof
功 能: 检测文件结束
用 法: int eof(int *handle);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
int handle;
char msg[] = "This is a test";
char ch;
/* create a file */
handle = open("DUMMY.FIL",
O_CREAT | O_RDWR,
S_IREAD | S_IWRITE);
/* write some data to the file */
write(handle, msg, strlen(msg));
/* seek to the beginning of the file */
lseek(handle, 0L, SEEK_SET);
reads chars from the file until hit EOF
do
read(handle, &ch, 1);
printf("%c", ch);
} while (!eof(handle));
close(handle);
return 0;
函数名: exec...
功 能: 装入并运行其它程序的函数
用 法: int execl(char *pathname, char *arg0, arg1, ..., argn, NULL);
int execle(char *pathname, char *arg0, arg1, ..., argn, NULL,
char *envp[]);
int execlp(char *pathname, char *arg0, arg1, .., NULL);
int execple(char *pathname, char *arg0, arg1, ..., NULL,
char *envp[]);
int execv(char *pathname, char *argv[]);
int execve(char *pathname, char *argv[], char *envp[]);
int execvp(char *pathname, char *argv[]);
int execvpe(char *pathname, char *argv[], char *envp[]);
程序例:
/* execv example */
#i nclude
#i nclude
#i nclude
void main(int argc, char *argv[])
int i;
printf("Command line arguments:\n");
for (i=0; i
printf("[%2d] : %s\n", i, argv);
printf("About to exec child with arg1 arg2 ...\n");
execv("CHILD.EXE", argv);
perror("exec error");
exit(1);
函数名: exit
功 能: 终止程序
用 法: void exit(int status);
程序例:
#i nclude
#i nclude
#i nclude
int main(void)
int status;
printf("Enter either 1 or 2\n");
status = getch();
/* Sets DOS errorlevel */
exit(status - '0');
/* Note: this line is never reached */
return 0;
函数名: exp
功 能: 指数函数
用 法: double exp(double x);
程序例:
#i nclude
#i nclude
int main(void)
double result;
double x = 4.0;
result = exp(x);
printf("'e' raised to the power \
of %lf (e ^ %lf) = %lf\n",
x, x, result);
return 0;
double fabs(double x);
返回双精度x的绝对值。
void far *farcalloc(unsigned long nunits,unsigned long unitsz);
堆中给含有nu从远nits个元素的,每个元素占用unitsz个字节长的数组分配存贮区。
成功是返回指向新分配的内存块的指针;若存贮空间不够,返回NULL。
unsigned long farcoreleft(void);
返回远堆中未用存贮区的大小。
void farfree(void far *block);
释放远堆中以前所分配内存块。
void far *farmalloc(unsigned long nbytes);
从远堆分配长nbytes字节的内存块,返回新地址。
void far *farrealloc(void far *oldblock,unsigned long nbytes);
调整已分配的内存块的大小为nbytes。需要的话,可把块中的内容复制到新位置。要注意:所有的可用的RAM可被分配,大于64K的块可被分配。
远指针用于存取被分配的块。返回重新分配的内存块的地址。若存贮块重新分配失败,返回NULL。
struct fcb {
char fcb_drive; /* 0 = default, 1 = A, 2 = B */
char fcb_name[8]; /* File name */
char fcb_ext[3]; /* File extension */
short fcb_curblk; /* Current block number */
short fcb_recsize; /* Logical record size in bytes */
long fcb_filsize; /* File size in bytes */
short fcb_date; /* Date file was last written */
char fcb_resv[10]; /* Reserved for DOS */
char fcb_currec; /* Current record in block */
long fcb_random; /* Random record number */
loveplc | 2006-8-24 09:40:00 | 显示全部楼层
int fclose(FILE *stream);
关闭一个流。
成功返回0;失败是返回EOF。
int fcloseall(void);
关闭所有打开的流,除了stdin,stdout,stdprn,stderr和stdaux。
char *fcvt(double value,int ndig,int *dec,int *sign);
把浮点数转换成字符串,把浮点数value转换成长度为ndig的以空字符终结的字符串,返回一个指向这个字符串的指针,相对于串的开始处,
小数点的位置,由dec间接存贮,dec若为负值,表示小数点在返回的字符串的左边。返回的字符串本身不带小数点。如果value的符号为负,由sign指向的值非零;否则它是零。
FILE *fdopen(int handle,char *type);
把流与一个文件描述字相联系地打开。fdopen使流stream与一个从creat,dup,dup2或open得到的文件描述字相联系。流的类型type必须与打开文件描述字handle的模式相匹配。
类型字符串type可以是下列值之一:
r,打开用于只读;
w,创建用于写;
a,打开用于写在原有内容后面,文件不存在时创建用于写;
r+,打开已存在的文件用于更新(读和写);
a+,添加打开,文件不存在时创建,在末尾更新。成功时返回新打开的流。出错时返回NULL。
int feof(FILE *stream);
测试所给stream的文件尾标记的宏。
若检测到文件尾标记EOF或Ctrl-z返回非零值;否则,返回0。
#i nclude
int ferror(FILE *stream);
测试给定流读写错误的宏。
若检测到给定流上的错误返回非0值。
struct ffblk {
char ff_reserved[21];
char ff_attrib;
unsigned ff_ftime;
unsigned ff_fdate;
long ff_fsize;
char ff_name[13];
int fflush(FILE *stream);
清除输入流的缓冲区,使它仍然打开,并把输出流的缓冲区的内容写入它所联系的文件中。成功时返回0,出错时返回EOF。
int fgetc(FILE *stream);
从流中读取下一个字符。
成功是返回输入流中的下一个字符;至文件结束或出错时返回EOF。
int fgetchar(void);
从标准输入流中读取字符,时定义为getc(stdin)的宏。
返回输入流stdin中的下一个字符,它已被转换成为无符号扩展的整形值。遇到出错或文件结束时返回EOF。
int fgetpos(FILE stream,fpos_t *pos);
取得当前文件指针。
fgetpos把与stream相联系的文件指针的位置保存在pos所指的地方。
其中,类型fpos_t在stdio.h中定义为
typeddf long fpos_t;
成功时返回0;失败时,返回非0值。
char *fgets(char *s,int n,FILE *stream);
成行读。
从流stream读n-1个字符,或遇换行符\'\\n\'为止,把读出的内容,存入s中。与gets不同,fgets在s未尾保留换行符。一个空字节被加入到s,用来标记串的结束。
成功时返回s所指的字符串;在出错或遇到文件结束时返回NULL。
long filelength(int handle);
返回与handle相联系的文件长度的字节数,出错时返回-1L。
int fileno(FILE *stream);
返回与stream相联系的文件描述字。
返回与stream相联系的文件描述字。
enum fill_patterns { /* Fill patterns for get/setfillstyle */
0 EMPTY_FILL, /* fills area in background color */
1 SOLID_FILL, /* fills area in solid fill color */
2 LINE_FILL, /* --- fill */
3 LTSLASH_FILL, /* /// fill */
4 SLASH_FILL, /* /// fill with thick lines */
5 BKSLASH_FILL, /* \\\\\\ fill with thick lines */
6 LTBKSLASH_FILL, /* \\\\\\ fill */
7 HATCH_FILL, /* light hatch fill */
8 XHATCH_FILL, /* heavy cross hatch fill */
9 INTERLEAVE_FILL, /* interleaving line fill */
10 WIDE_DOT_FILL, /* Widely spaced dot fill */
11 CLOSE_DOT_FILL, /* Closely spaced dot fill */
12 USER_FILL /* user defined fill */
void far fillellipse(int x,int y,int xradius,int yradius);
画一填充椭圆。
以(x,y)为中心,以xradius和yradius为水平和垂直半轴,用当前颜色画边线,画一椭圆,用当前填充颜色和填充方式填充。
int findfirst(const char *pathname,struct ffblk *ffblk,int attrib);
搜索磁盘目录。开始通过DOS系统调用0x4E对磁盘目录进行搜索。pathname中可含有要找的盘区路径文件名。
文件名中可含有通配符(如*或?)。如果找到了匹配的文件,把文件目录信息填入ffblk结构。
attrib是MS-DOS的文件属性字节,用于在搜索过程中选择符合条件的文件。
attrib可以是在dos.h中定义的下列可取值之一:FA_RDONLY,只读;FA_HIDDEN隐藏;FA_SYSTEM系统文件;FA_LABEL卷标;FA_DIREC,目录;FA_ARCH,档案.可参考>.
结构ffblk的格式如下:
struct ffblk{
char ff_reserved[21}; /*由DOS保留*/
char ff_attrib; /*属性查找*/
int ff_ftime; /*文件时间*/
int f_fdate; /*文件日期*/
long ff_fsize; /*文件大小*/
char ff_name[13}; /*找到的文件名*/
在成功的地找到了与搜索路径pathname相匹配的文件名后返回0;否则返回-1。
int findnext(xtruct ffblk *ffblk);继续按findfirst的pathname搜索磁盘目录。
成功地找到了与搜索路径pathname相匹配的后续文件名后返回0;否则返回-1。
void far floodfill(int x,int y, int border);
填充一个有界的区域。
double floor(double x);
返回〈=x的用双精度浮点数表示的最大整数。
int flushall(void);
清除所有缓冲区。
清除所有与打开输入流相联系的缓冲区,并把所有和打开输出流相联系的缓冲区的内容写入到各自的文件中,跟在flushall后面的读操作,从输入文件中读新数据到缓冲区中。
返回一个表示打开输入流和输出流总数的整数。
faye1024 | 2008-1-25 14:03:00 | 显示全部楼层
去看实例4
wydqsb | 2008-4-20 01:38:00 | 显示全部楼层
太好了,我刚开始学习能用上.
谢谢
