C语言库函数大全及应用实例五
查看2288 | 回复5 | 2006-8-24 09:36:00 | 显示全部楼层 |阅读模式
C语言库函数大全及应用实例五
函数名: getcurdir
功 能: 取指定驱动器的当前目录
用 法: int getcurdir(int drive, char *direc);
程序例:
#i nclude
#i nclude
#i nclude
char *current_directory(char *path)
strcpy(path, "X:\\"); /* fill string with form of response: X:\ */
path[0] = 'A' + getdisk(); /* replace X with current drive letter */
getcurdir(0, path+3); /* fill rest of string with current directory */
return(path);
int main(void)
char curdir[MAXPATH];
current_directory(curdir);
printf("The current directory is %s\n", curdir);
return 0;
函数名: getcwd
功 能: 取当前工作目录
用 法: char *getcwd(char *buf, int n);
程序例:
#i nclude
#i nclude
int main(void)
char buffer[MAXPATH];
getcwd(buffer, MAXPATH);
printf("The current directory is: %s\n", buffer);
return 0;
函数名: getdate
功 能: 取DOS日期
用 法: void getdate(struct *dateblk);
程序例:
#i nclude
#i nclude
int main(void)
struct date d;
getdate(&d);
printf("The current year is: %d\n",
d.da_year);
printf("The current day is: %d\n",
d.da_day);
printf("The current month is: %d\n",
d.da_mon);
return 0;
函数名: getdefaultpalette
功 能: 返回调色板定义结构
用 法: struct palettetype *far getdefaultpalette(void);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
/* request auto detection */
int gdriver = DETECT, gmode, errorcode;
int i;
/* structure for returning palette copy */
struct palettetype far *pal=(void *) 0;
/* initialize graphics and local variables */
initgraph(&gdriver, &gmode, "");
/* read result of initialization */
errorcode = graphresult();
/* an error occurred */
if (errorcode != grOk)
printf("Graphics error: %s\n",
grapherrormsg(errorcode));
printf("Press any key to halt:");
getch();
/* terminate with an error code */
exit(1);
setcolor(getmaxcolor());
/* return a pointer to the default palette */
pal = getdefaultpalette();
for (i=0; i<16; i++)
printf("colors[%d] = %d\n", i,
pal->colors);
getch();
/* clean up */
getch();
closegraph();
return 0;
函数名: getdisk
功 能: 取当前磁盘驱动器号
用 法: int getdisk(void);
程序例:
#i nclude
#i nclude
int main(void)
int disk;
disk = getdisk() + 'A';
printf("The current drive is: %c\n",
disk);
return 0;
函数名: getdrivername
功 能: 返回指向包含当前图形驱动程序名字的字符串指针
用 法: char *getdrivename(void);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
/* stores the device driver name */
char *drivername;
getch();
exit(1);
/* get name of the device driver in use */
drivername = getdrivername();
/* for centering text on the screen */
settextjustify(CENTER_TEXT, CENTER_TEXT);
/* output the name of the driver */
outtextxy(getmaxx() / 2, getmaxy() / 2,
drivername);
/* clean up */
getch();
closegraph();
return 0;
函数名: getdta
功 能: 取磁盘传输地址
用 法: char far *getdta(void);
程序例:
#i nclude
#i nclude
int main(void)
char far *dta;
dta = getdta();
printf("The current disk transfer \
address is: %Fp\n", dta);
return 0;
函数名: getenv
功 能: 从环境中取字符串
用 法: char *getenv(char *envvar);
程序例:
#i nclude
#i nclude
int main(void)
char *s;
s=getenv("COMSPEC"); /* get the comspec environment parameter */
printf("Command processor: %s\n",s); /* display comspec parameter */
return 0;
函数名: getfat, getfatd
功 能: 取文件分配表信息
用 法: void getfat(int drive, struct fatinfo *fatblkp);
程序例:
#i nclude
#i nclude
int main(void)
struct fatinfo diskinfo;
int flag = 0;
printf("Please insert disk in drive A\n");
getchar();
getfat(1, &diskinfo);
/* get drive information */
printf("\nDrive A: is ");
switch((unsigned char) diskinfo.fi_fatid)
case 0xFD:
printf("360K low density\n");
break;
case 0xF9:
printf("1.2 Meg high density\n");
break;
default:
printf("unformatted\n");
flag = 1;
if (!flag)
printf(" sectors per cluster %5d\n",
diskinfo.fi_sclus);
printf(" number of clusters %5d\n",
diskinfo.fi_nclus);
printf(" bytes per sector %5d\n",
diskinfo.fi_bysec);
return 0;
函数名: getfillpattern
功 能: 将用户定义的填充模式拷贝到内存中
用 法: void far getfillpattern(char far *upattern);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
int maxx, maxy;
char pattern[8] = {0x00, 0x70, 0x20, 0x27, 0x25, 0x27, 0x04, 0x04};
if (errorcode != grOk) /* an error occurred */
printf("Graphics error: %s\n", grapherrormsg(errorcode));
getch();
exit(1); /* terminate with an error code */
maxx = getmaxx();
maxy = getmaxy();
/* select a user defined fill pattern */
setfillpattern(pattern, getmaxcolor());
/* fill the screen with the pattern */
bar(0, 0, maxx, maxy);
getch();
/* get the current user defined fill pattern */
getfillpattern(pattern);
/* alter the pattern we grabbed */
pattern[4] -= 1;
pattern[5] -= 3;
pattern[6] += 3;
pattern[7] -= 4;
/* select our new pattern */
/* fill the screen with the new pattern */
/* clean up */
getch();
closegraph();
return 0;
函数名: getfillsettings
功 能: 取得有关当前填充模式和填充颜色的信息
用 法: void far getfillsettings(struct fillsettingstype far *fillinfo);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
/ the names of the fill styles supported */
char *fname[] = { "EMPTY_FILL",
"SOLID_FILL",
"LINE_FILL",
"LTSLASH_FILL",
"SLASH_FILL",
"BKSLASH_FILL",
"LTBKSLASH_FILL",
"HATCH_FILL",
"XHATCH_FILL",
"INTERLEAVE_FILL",
"WIDE_DOT_FILL",
"CLOSE_DOT_FILL",
"USER_FILL"
int main(void)
struct fillsettingstype fillinfo;
int midx, midy;
char patstr[40], colstr[40];
getch();
midx = getmaxx() / 2;
midy = getmaxy() / 2;
/* get information about current fill pattern and color */
getfillsettings(&fillinfo);
/* convert fill information into strings */
sprintf(patstr, "%s is the fill style.", fname[fillinfo.pattern]);
sprintf(colstr, "%d is the fill color.", fillinfo.color);
/* display the information */
outtextxy(midx, midy, patstr);
outtextxy(midx, midy+2*textheight("W"), colstr);
/* clean up */
getch();
closegraph();
return 0;
函数名: getftime
功 能: 取文件日期和时间
用 法: int getftime(int handle, struct ftime *ftimep);
程序例:
#i nclude
#i nclude
int main(void)
FILE *stream;
struct ftime ft;
if ((stream = fopen("TEST.$$$",
"wt")) == NULL)
fprintf(stderr,
"Cannot open output file.\n");
return 1;
getftime(fileno(stream), &ft);
printf("File time: %u:%u:%u\n",
ft.ft_hour, ft.ft_min,
ft.ft_tsec * 2);
printf("File date: %u/%u/%u\n",
ft.ft_month, ft.ft_day,
ft.ft_year+1980);
fclose(stream);
return 0;
loveplc | 2006-8-24 09:36:00 | 显示全部楼层
函数名: getgraphmode
功 能: 返回当前图形模式
用 法: int far getgraphmode(void);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
int midx, midy, mode;
char numname[80], modename[80];
initgraph(&gdriver, &gmode, \"\");
printf(\"Graphics error: %s\\n\",
printf(\"Press any key to halt:\");
getch();
exit(1);
/* get mode number and name strings */
mode = getgraphmode();
sprintf(numname,
\"%d is the current mode number.\",
mode);
sprintf(modename,
\"%s is the current graphics mode\",
getmodename(mode));
outtextxy(midx, midy, numname);
outtextxy(midx, midy+2*textheight(\"W\"),
modename);
/* clean up */
getch();
closegraph();
return 0;
函数名: getftime
功 能: 取文件日期和时间
程序例:
#i nclude
#i nclude
int main(void)
FILE *stream;
struct ftime ft;
if ((stream = fopen(\"TEST.$$$\",
\"wt\")) == NULL)
fprintf(stderr,
\"Cannot open output file.\\n\");
return 1;
printf(\"File time: %u:%u:%u\\n\",
ft.ft_tsec * 2);
printf(\"File date: %u/%u/%u\\n\",
ft.ft_year+1980);
fclose(stream);
return 0;
函数名: getgraphmode
功 能: 返回当前图形模式
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
getch();
exit(1);
sprintf(numname,
mode);
sprintf(modename,
getmodename(mode));
modename);
/* clean up */
getch();
closegraph();
return 0;
函数名: getimage
功 能: 将指定区域的一个位图存到主存中
用 法: void far getimage(int left, int top, int right, int bottom,
void far *bitmap);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
#i nclude
void save_screen(void far *buf[4]);
void restore_screen(void far *buf[4]);
int maxx, maxy;
int main(void)
int gdriver=DETECT, gmode, errorcode;
void far *ptr[4];
/* auto-detect the graphics driver and mode */
errorcode = graphresult(); /* check for any errors */
printf(\"Graphics error: %s\\n\", grapherrormsg(errorcode));
getch();
exit(1);
maxx = getmaxx();
maxy = getmaxy();
/* draw an image on the screen */
rectangle(0, 0, maxx, maxy);
line(0, 0, maxx, maxy);
line(0, maxy, maxx, 0);
save_screen(ptr); /* save the current screen */
getch(); /* pause screen */
cleardevice(); /* clear screen */
restore_screen(ptr); /* restore the screen */
closegraph();
return 0;
unsigned size;
int ystart=0, yend, yincr, block;
yincr = (maxy+1) / 4;
yend = yincr;
size = imagesize(0, ystart, maxx, yend); /* get byte size of image */
for (block=0; block<=3; block++)
if ((buf[block] = farmalloc(size)) == NULL)
closegraph();
printf(\"Error: not enough heap space in save_screen().\\n\");
exit(1);
getimage(0, ystart, maxx, yend, buf[block]);
ystart = yend + 1;
yend += yincr + 1;
unsigned size;
yend = yincr;
closegraph();
exit(1);
ystart = yend + 1;
yend += yincr + 1;
yend = yincr;
putimage(0, ystart, buf[block], COPY_PUT);
farfree(buf[block]);
ystart = yend + 1;
yend += yincr + 1;
YUANJINGHAO1129 | 2007-1-17 08:50:00 | 显示全部楼层
谢谢,楼主
wj14378 | 2007-1-28 05:02:00 | 显示全部楼层
太强了
faye1024 | 2008-1-25 14:09:00 | 显示全部楼层
去看实例6
lthlycyj | 2009-3-26 22:32:00 | 显示全部楼层
謝謝分享!\"\"
