C语言库函数大全及应用实例十
查看2440 | 回复7 | 2006-8-24 09:19:00 | 显示全部楼层 |阅读模式
C语言库函数大全及应用实例十
函数名: qsort
功 能: 使用快速排序例程进行排序
用 法: void qsort(void *base, int nelem, int width, int (*fcmp)());
程序例:
#i nclude
#i nclude
#i nclude
int sort_function( const void *a, const void *b);
char list[5][4] = { "cat", "car", "cab", "cap", "can" };
int main(void)
int x;
qsort((void *)list, 5, sizeof(list[0]), sort_function);
for (x = 0; x < 5; x++)
printf("%s\n", list[x]);
return 0;
return( strcmp(a,b) );
函数名: qsort
功 能: 使用快速排序例程进行排序
程序例:
#i nclude
#i nclude
#i nclude
int main(void)
int x;
return 0;
函数名: raise
功 能: 向正在执行的程序发送一个信号
用 法: int raise(int sig);
程序例:
#i nclude
int main(void)
int a, b;
a = 10;
b = 0;
if (b == 0)
/* preempt divide by zero error */
raise(SIGFPE);
a = a / b;
return 0;
函数名: rand
功 能: 随机数发生器
用 法: void rand(void);
程序例:
#i nclude
#i nclude
int main(void)
int i;
printf("Ten random numbers from 0 to 99\n\n");
for(i=0; i<10; i++)
printf("%d\n", rand() % 100);
return 0;
函数名: randbrd
功 能: 随机块读
用 法: int randbrd(struct fcb *fcbptr, int reccnt);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
char far *save_dta;
char line[80], buffer[256];
struct fcb blk;
int i, result;
/* get user input file name for dta */
printf("Enter drive and file name (no path - i.e. a:file.dat)\n");
gets(line);
/* put file name in fcb */
if (!parsfnm(line, &blk, 1))
printf("Error in call to parsfnm\n");
exit(1);
printf("Drive #%d file: %s\n\n", blk.fcb_drive, blk.fcb_name);
/* open file with DOS FCB open file */
bdosptr(0x0F, &blk, 0);
/* save old dta, and set new one */
save_dta = getdta();
setdta(buffer);
/* set up info for the new dta */
blk.fcb_recsize = 128;
blk.fcb_random = 0L;
result = randbrd(&blk, 1);
/* check results from randbrd */
if (!result)
printf("Read OK\n\n");
else
perror("Error during read");
exit(1);
/* read in data from the new dta */
printf("The first 128 characters are:\n");
for (i=0; i<128; i++)
putchar(buffer);
/* restore previous dta */
setdta(save_dta);
return 0;
函数名: randbwr
功 能: 随机块写
用 法: int randbwr(struct fcp *fcbptr, int reccnt);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
char far *save_dta;
char line[80];
char buffer[256] = "RANDBWR test!";
struct fcb blk;
int result;
/* get new file name from user */
printf("Enter a file name to create (no path - ie. a:file.dat\n");
gets(line);
/* parse the new file name to the dta */
parsfnm(line,&blk,1);
printf("Drive #%d file: %s\n", blk.fcb_drive, blk.fcb_name);
/* request DOS services to create file */
if (bdosptr(0x16, &blk, 0) == -1)
perror("Error creating file");
exit(1);
/* save old dta and set new dta */
setdta(buffer);
/* write new records */
blk.fcb_recsize = 256;
result = randbwr(&blk, 1);
if (!result)
printf("Write OK\n");
else
perror("Disk error");
exit(1);
/* request DOS services to close the file */
if (bdosptr(0x10, &blk, 0) == -1)
perror("Error closing file");
exit(1);
/* reset the old dta */
setdta(save_dta);
return 0;
函数名: random
功 能: 随机数发生器
用 法: int random(int num);
程序例:
#i nclude
#i nclude
#i nclude
/* prints a random number in the range 0 to 99 */
int main(void)
randomize();
printf("Random number in the 0-99 range: %d\n", random (100));
return 0;
函数名: randomize
功 能: 初始化随机数发生器
用 法: void randomize(void);
程序例:
#i nclude
#i nclude
#i nclude
int main(void)
int i;
randomize();
for(i=0; i<10; i++)
return 0;
函数名: read
功 能: 从文件中读
用 法: int read(int handle, void *buf, int nbyte);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
void *buf;
int handle, bytes;
buf = malloc(10);
Looks for a file in the current directory named TEST.$$$ and attempts
to read 10 bytes from it. To use this example you should create the
file TEST.$$$
if ((handle =
open("TEST.$$$", O_RDONLY | O_BINARY, S_IWRITE | S_IREAD)) == -1)
printf("Error Opening File\n");
exit(1);
if ((bytes = read(handle, buf, 10)) == -1) {
printf("Read Failed.\n");
exit(1);
else {
printf("Read: %d bytes read.\n", bytes);
return 0;
函数名: realloc
功 能: 重新分配主存
用 法: void *realloc(void *ptr, unsigned newsize);
程序例:
#i nclude
#i nclude
#i nclude
int main(void)
char *str;
/* allocate memory for string */
str = malloc(10);
/* copy "Hello" into string */
strcpy(str, "Hello");
printf("String is %s\n Address is %p\n", str, str);
str = realloc(str, 20);
printf("String is %s\n New address is %p\n", str, str);
/* free memory */
free(str);
return 0;
函数名: rectangle
功 能: 画一个矩形
用 法: void far rectangle(int left, int top, int right, int bottom);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
/* request auto detection */
int gdriver = DETECT, gmode, errorcode;
int left, top, right, bottom;
/* initialize graphics and local variables */
initgraph(&gdriver, &gmode, "");
/* read result of initialization */
errorcode = graphresult();
if (errorcode != grOk) /* an error occurred */
printf("Graphics error: %s\n", grapherrormsg(errorcode));
printf("Press any key to halt:");
getch();
exit(1); /* terminate with an error code */
left = getmaxx() / 2 - 50;
top = getmaxy() / 2 - 50;
right = getmaxx() / 2 + 50;
bottom = getmaxy() / 2 + 50;
/* draw a rectangle */
rectangle(left,top,right,bottom);
/* clean up */
getch();
closegraph();
return 0;
函数名: registerbgidriver
功 能: 登录已连接进来的图形驱动程序代码
用 法: int registerbgidriver(void(*driver)(void));
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
/* register a driver that was added into graphics.lib */
errorcode = registerbgidriver(EGAVGA_driver);
/* report any registration errors */
if (errorcode < 0)
getch();
getch();
/* draw a line */
line(0, 0, getmaxx(), getmaxy());
/* clean up */
getch();
closegraph();
return 0;
函数名: remove
功 能: 删除一个文件
用 法: int remove(char *filename);
程序例:
#i nclude
int main(void)
char file[80];
/* prompt for file name to delete */
printf("File to delete: ");
gets(file);
/* delete the file */
if (remove(file) == 0)
printf("Removed %s.\n",file);
else
perror("remove");
return 0;
loveplc | 2006-8-24 09:20:00 | 显示全部楼层
函数名: rename
功 能: 重命名文件
用 法: int rename(char *oldname, char *newname);
程序例:
#i nclude
int main(void)
char oldname[80], newname[80];
/* prompt for file to rename and new name */
printf(\"File to rename: \");
gets(oldname);
printf(\"New name: \");
gets(newname);
/* Rename the file */
if (rename(oldname, newname) == 0)
printf(\"Renamed %s to %s.\\n\", oldname, newname);
else
perror(\"rename\");
return 0;
函数名: restorecrtmode
功 能: 将屏幕模式恢复为先前的imitgraph设置
用 法: void far restorecrtmode(void);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
int x, y;
initgraph(&gdriver, &gmode, \"\");
printf(\"Graphics error: %s\\n\", grapherrormsg(errorcode));
printf(\"Press any key to halt:\");
getch();
x = getmaxx() / 2;
y = getmaxy() / 2;
/* output a message */
settextjustify(CENTER_TEXT, CENTER_TEXT);
outtextxy(x, y, \"Press any key to exit graphics:\");
getch();
/* restore system to text mode */
restorecrtmode();
printf(\"We\'re now in text mode.\\n\");
printf(\"Press any key to return to graphics mode:\");
getch();
/* return to graphics mode */
setgraphmode(getgraphmode());
outtextxy(x, y, \"We\'re back in graphics mode.\");
outtextxy(x, y+textheight(\"W\"), \"Press any key to halt:\");
/* clean up */
getch();
closegraph();
return 0;
函数名: rewind
功 能: 将文件指针重新指向一个流的开头
用 法: int rewind(FILE *stream);
程序例:
#i nclude
#i nclude
int main(void)
FILE *fp;
char *fname = \"TXXXXXX\", *newname, first;
newname = mktemp(fname);
fp = fopen(newname,\"w+\");
fprintf(fp,\"abcdefghijklmnopqrstuvwxyz\");
rewind(fp);
fscanf(fp,\"%c\",&first);
printf(\"The first character is: %c\\n\",first);
fclose(fp);
remove(newname);
return 0;
函数名: rmdir
功 能: 删除DOS文件目录
用 法: int rmdir(char *stream);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
#define DIRNAME \"testdir.$$$\"
int main(void)
int stat;
stat = mkdir(DIRNAME);
if (!stat)
printf(\"Directory created\\n\");
else
printf(\"Unable to create directory\\n\");
exit(1);
getch();
system(\"dir/p\");
getch();
stat = rmdir(DIRNAME);
if (!stat)
printf(\"\\nDirectory deleted\\n\");
else
perror(\"\\nUnable to delete directory\\n\");
exit(1);
return 0;
函数名: sbrk
功 能: 改变数据段空间位置
用 法: char *sbrk(int incr);
程序例:
#i nclude
#i nclude
int main(void)
printf(\"Changing allocation with sbrk()\\n\");
printf(\"Before sbrk() call: %lu bytes free\\n\",
(unsigned long) coreleft());
sbrk(1000);
printf(\" After sbrk() call: %lu bytes free\\n\",
return 0;
函数名: scanf
功 能: 执行格式化输入
用 法: int scanf(char *format[,argument,...]);
程序例:
#i nclude
#i nclude
int main(void)
char label[20];
char name[20];
int entries = 0;
int loop, age;
double salary;
struct Entry_struct
char name[20];
int age;
float salary;
} entry[20];
/* Input a label as a string of characters restricting to 20 characters */
printf(\"\\n\\nPlease enter a label for the chart: \");
scanf(\"%20s\", label);
fflush(stdin); /* flush the input stream in case of bad input */
/* Input number of entries as an integer */
printf(\"How many entries will there be? (less than 20) \");
scanf(\"%d\", &entries);
/* input a name restricting input to only letters upper or lower case */
for (loop=0;loop
printf(\"Entry %d\\n\", loop);
printf(\" Name : \");
scanf(\"%[A-Za-z]\", entry[loop].name);
/* input an age as an integer */
printf(\" Age : \");
scanf(\"%d\", &entry[loop].age);
/* input a salary as a float */
printf(\" Salary : \");
scanf(\"%f\", &entry[loop].salary);
/* Input a name, age and salary as a string, integer, and double */
printf(\"\\nPlease enter your name, age and salary\\n\");
scanf(\"%20s %d %lf\", name, &age, &salary);
/* Print out the data that was input */
printf(\"\\n\\nTable %s\\n\",label);
printf(\"Compiled by %s age %d $%15.2lf\\n\", name, age, salary);
printf(\"-----------------------------------------------------\\n\");
for (loop=0;loop
printf(\"%4d | %-20s | %5d | %15.2lf\\n\",
loop + 1,
entry[loop].name,
entry[loop].age,
return 0;
函数名: searchpath
功 能: 搜索DOS路径
用 法: char *searchpath(char *filename);
程序例:
#i nclude
#i nclude
int main(void)
char *p;
/* Looks for TLINK and returns a pointer
to the path */
p = searchpath(\"TLINK.EXE\");
printf(\"Search for TLINK.EXE : %s\\n\", p);
/* Looks for non-existent file */
p = searchpath(\"NOTEXIST.FIL\");
printf(\"Search for NOTEXIST.FIL : %s\\n\", p);
return 0;
函数名: sector
功 能: 画并填充椭圆扇区
用 法: void far sector(int x, int y, int stangle, int endangle);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
int midx, midy, i;
int stangle = 45, endangle = 135;
int xrad = 100, yrad = 50;
getch();
midx = getmaxx() / 2;
midy = getmaxy() / 2;
/* loop through the fill patterns */
for (i=EMPTY_FILL; i
/* set the fill style */
setfillstyle(i, getmaxcolor());
/* draw the sector slice */
sector(midx, midy, stangle, endangle, xrad, yrad);
getch();
/* clean up */
closegraph();
return 0;
函数名: segread
功 能: 读段寄存器值
用 法: void segread(struct SREGS *segtbl);
程序例:
#i nclude
#i nclude
int main(void)
struct SREGS segs;
segread(&segs);
printf(\"Current segment register settings\\n\\n\");
printf(\"CS: %X DS: %X\\n\", segs.cs, segs.ds);
printf(\"ES: %X SS: %X\\n\", segs.es, segs.ss);
return 0;
函数名: setactivepage
功 能: 设置图形输出活动页
用 法: void far setactivepage(int pagenum);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
/* select a driver and mode that supports */
/* multiple pages. */
int gdriver = EGA, gmode = EGAHI, errorcode;
int x, y, ht;
getch();
x = getmaxx() / 2;
y = getmaxy() / 2;
ht = textheight(\"W\");
/* select the off screen page for drawing */
setactivepage(1);
/* draw a line on page #1 */
/* output a message on page #1 */
outtextxy(x, y, \"This is page #1:\");
outtextxy(x, y+ht, \"Press any key to halt:\");
/* select drawing to page #0 */
setactivepage(0);
/* output a message on page #0 */
outtextxy(x, y, \"This is page #0.\");
outtextxy(x, y+ht, \"Press any key to view page #1:\");
getch();
/* select page #1 as the visible page */
setvisualpage(1);
/* clean up */
getch();
closegraph();
return 0;
函数名: setallpallette
功 能: 按指定方式改变所有的调色板颜色
用 法: void far setallpallette(struct palette, far *pallette);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
struct palettetype pal;
int color, maxcolor, ht;
int y = 10;
char msg[80];
getch();
maxcolor = getmaxcolor();
ht = 2 * textheight(\"W\");
/* grab a copy of the palette */
getpalette(&pal);
/* display the default palette colors */
for (color=1; color<=maxcolor; color++)
setcolor(color);
sprintf(msg, \"Color: %d\", color);
outtextxy(1, y, msg);
y += ht;
/* wait for a key */
getch();
/* black out the colors one by one */
setpalette(color, BLACK);
getch();
/* restore the palette colors */
setallpalette(&pal);
/* clean up */
getch();
closegraph();
return 0;
函数名: setaspectratio
功 能: 设置图形纵横比
用 法: void far setaspectratio(int xasp, int yasp);
程序例:
#i nclude
#i nclude
#i nclude
#i nclude
int main(void)
int xasp, yasp, midx, midy;
getch();
setcolor(getmaxcolor());
/* get current aspect ratio settings */
getaspectratio(&xasp, &yasp);
/* draw normal circle */
circle(midx, midy, 100);
getch();
/* claer the screen */
cleardevice();
/* adjust the aspect for a wide circle */
setaspectratio(xasp/2, yasp);
getch();
/* adjust the aspect for a narrow circle */
cleardevice();
setaspectratio(xasp, yasp/2);
/* clean up */
getch();
closegraph();
return 0;
YUANJINGHAO1129 | 2007-1-17 09:12:00 | 显示全部楼层
不错
YUANJINGHAO1129 | 2007-1-17 09:13:00 | 显示全部楼层
就是程序不完整
YUANJINGHAO1129 | 2007-1-17 12:21:00 | 显示全部楼层
对了,你想表达什么意思呢
wj14378 | 2007-1-28 05:04:00 | 显示全部楼层
太强了
faye1024 | 2008-1-25 14:22:00 | 显示全部楼层
去看实例11
lthlycyj | 2009-3-26 22:30:00 | 显示全部楼层
謝謝分享!
