iFIX经典问答
查看3232 | 回复6 | 2008-3-15 21:42:00 | 显示全部楼层 |阅读模式
iFIX经典问题问答
1:iFIX中如何使用vba开启和停止wsqlodcalarmsODBC
Description
The ability to stop or start the SQL task, wsqlodc, and to pause or continue the alarms to
ODBC task used to only be available by launching Mission Control and manually controlling them.
The ability to perform this control programmatically using VBA was added as part of a SIM for
iFix 2.5. The function calls to allow this are not widely documented and are shown below: -
Resolution
Declare Function TurnOnSqlTask Lib "missionvba" (ByVal cmd$) As Long
'Turns on a SQL task. The cmd$ parameter is the command line passed to the SQL task
'Return of 0 is a success. Current logged in user must have security rights to turn
'on/off SAC. If a non-zero error code is returned, you can use the err2str
'utility in the fix base directory to translate the error to a string
Declare Function TurnOffSqlTask Lib "missionvba" () As Long
'Turns off a SQL task. Return of 0 is a success. Current logged in user must
'have security rights to turn on/off SAC. If a non-zero error code is returned,
'you can use the err2str utility in the fix base directory to translate the error to a string
Declare Function PauseAlarmODBC Lib "missionvba" () As Long
'Pauses the AlarmODBC task. Return of 0 is a success. Current logged in user does NOT
'have to have security rights.
'This function will execute regardless of the "Allow Operator to Pause Alarm Logging"
'Setting found in the iFIX ODBC Alarm Service Configurator of the System Configuration
'Utility.
Private Declare Function ContinueAlarmODBC Lib "missionvba" () As Long
'Resumes the AlarmODBC task. Return of 0 is a success. Current logged in user does NOT
'Utility.
'All of these functions will block until the request is completed.
2
iFIX如何使用vba开启和停止基于时间和事件的调度?
Description
This solution shows how to start and stop a time-based or event-based schedule
running in the background.
Resolution
STOP / START a EVENT BASED SCHEDULE
To Start:
Private Sub CommandButton1_Click()
Dim Var1 As Object
Dim Var2 As Object
Set Var1 = GetObject(, "FixBackGroundServer.Application")
Set Var2 = Var1.System.FindObject("SchedTest1.FIXEvent1")
Var2.StartEvent
End Sub
To Stop:
Dim Var1 As Object
Dim Var2 As Object
Var2.StopEvent
End Sub
STOP / START a TIME BASED SCHEDULE
To Stop the TimerObject:
Dim Var1 As Object
Dim Var2 As Object
Set Var1 = GetObject (,"FixBackGroundServer.Application")
Set Var2 = Var1.System.FindObject("Sched1.Timer1")
Var2.TimerEnabled = False
End Sub
To Start the TimerObject:
Private Sub CommandButton2_Click()
Dim Var1 As Object
Dim Var2 As Object
Set Var2 = Var1.System.FindObject("sched.Timer1")
Var2.TimerEnabled = True
Var2.StartTimer
End Sub
3
iFIX如何使用vba进行网络打印机打印?
Description
The following is an example of printing an Excel Document to a Network Printer or a printer other than the
default printer on the machine.
Dim objXL As Object
Dim myDoc As Object
Set objXL = CreateObject("Excel.Application")
Set myDoc = objXL.Workbooks.Open("C:\testfile.xls", , True)
myDoc.Printout copies:=1, preview:=False, ActivePrinter:="'\\SERVER\PRINTER", printtofile:=False, collate:=True
myDoc.Close
Set objXL = Nothing
Set myDoc = Nothing
References
If this script is used in a background schedule with FixBackgroundServer configured to run as a Service, the Fix
service must run under a user account that has printers defined. See KnowledgeBase Article i013417 for more
information on this configuration.
The Printout command can be used for other document types (Word, PowerPoint, etc), however different syntax
is required, refer to
http://msdn.microsoft.com for other examples.
4
iFIX报警状态代码以及意义?
Description
FIX displays alarm status codes for each alarm in the Alarm Summary Link. What is the meaning of each of these codes?
Resolution
Priority --> Alarm Type --> Description
1 --> COMM --> Communication Error ("BAD" value)
1 --> OCD --> Open circuit detected
1 --> OVER --> Over Range
1 --> UNDER --> Under Range
1 --> ERROR --> Any Statistical Data block alarm
2 --> CFN --> Change from normal alarm (digital blocks only)
2 --> COS --> Change of State alarm (digital blocks only)
2 --> HIHI --> Block in HIHI alarm state
2 --> LOLO --> Block in LOLO alarm state
3 --> RATE --> Value exceeds rate-of-change setting
3 --> HI --> Block in HI alarm state
3 --> LO --> Block in LO alarm state
4 --> DEV --> Deviation Alarm
5 --> OK --> Block in normal state
5
:如何禁止和使能7X驱动标签点(对驱动自动禁止特别有用)
Dim opcDriver As New OPCDrv.OPCServer
Dim objDriver As Object
Dim strDRVAcronym As String
Dim strProgId As String
''Variables for GetChannel
Dim lngNumChannels As Long
Dim lngChanHandles
Dim strChanNames
''Variables for GetDevices
Dim lngNumDevices As Long
Dim lngDeviceHandles
Dim strDeviceNames
''Variables for GetDataBlocks
Dim lngNumDataBlocks As Long
Dim lngDataBlockHandles
Dim strDataBlockNames
Dim i As Integer
Dim j As Integer
Dim lngErrors
Dim myvar As Long
Dim readEnable
'strDRVAcronym = InputBox("Please enter the driver''s three letter acronym?" & vbCrLf & "(For Example:
Enter ABR for the ABR Driver)", "What Driver are you using?")
'strProgId = "Intellution." & strDRVAcronym & "drv"
'strProgId = "Matrikon.OPC.Simulation.1"
'Set objDriver = CreateObject(strProgId)
lngNumChannels = opcDriver.GetChannels(lngChanHandles, strChanNames)
''Build Variables for SetPropertyData function.
lngHandle = lngDataBlockHandles(0)
varProperties = "Enabled"
varProperyData = "1"
opcDriver.GetPropertyData lngChanHandles(1), varProperties, readEnable
对服器1置真
If readEnable = "0" Then
lngErrors = opcDriver.SetPropertyData(lngChanHandles(1), varProperties, varProperyData)
End If
lngNumDevices = opcDriver.GetDevices(lngChanHandles(1), lngDeviceHandles, strDeviceNames)
lngNumDataBlocks = opcDriver.GetDataBlocks(lngDeviceHandles(0), lngDataBlockHandles, strDataBlockNames)
读工作组
opcDriver.GetPropertyData lngDeviceHandles(0), varProperties, readEnable
lngErrors = opcDriver.SetPropertyData(lngDeviceHandles(0), varProperties, varProperyData)
End If
处理工作块
opcDriver.GetPropertyData lngDataBlockHandles(0), varProperties, readEnable
For i = 0 To 1
lngErrors = opcDriver.SetPropertyData(lngDataBlockHandles(i), varProperties, varProperyData)
Next i
End If
Set opcDriver = Nothing
6
iFIX_如何使用脚本实现驱动(7x)的启动和停止?
Description
The following solution explains how to Start and Stop a 7.x driver through VBA code. This example uses
the ABR driver. To implement this with another 7.x driver, change the ABR to the three letter acronym of
the other driver and switch the reference to that driver.
Resolution
This code will only work with 7.x drivers. If you want to implement this is code in a new picture you
need to set a reference to Intellution ABRDrv OPC Server 7.20 Library. To set a reference, use the following steps:
1) On the Tools menu in the VB Editor choose References.
2) Select the Intellution ABRDrv OPC Server 7.20 Library from the list.
Add two command buttons to your picture and name them cmdStart_Click and cmdStop_Click.
Then paste the following code into the picture:
Private Sub cmdStart_Click()
Dim ABRDriver As New ABRDrv.ABRServer
ABRDriver.Stop
Set ABRDriver = Nothing
End Sub
Private Sub cmdStop_Click()
ABRDriver.Start
End Sub
7
iFIX_如何使用脚本实现驱动(6x)的启动和停止?
Description
This articles describes how to control (start or stop) the 6.x drivers through VBA, Command Script,
or DOS rather than in Mission Control.
Resolution
The attached application DCTRL61.EXE enables you to do this. Below are the usage instructions.
Usage: DCTRL command driver acronym delay [sleep]
where command is:
START - start the driver
STOP - stop the driver from polling
STOP_EXIT - stop polling and exit
SLEEP - set new sleep time (period)
STATUS - displays current values
DELAY - Wait a Number of milliseconds before executing this command ( 1000 = 1 second).
The the dctrl61.exe must be located in the FIX32 or Dynamics directory. The command and driver
acronym must be in ALL CAPS.
Example from the DOS prompt: dctrl60 START MBR
Example from a iFIX VBA: Shell c:\fix32\dctrl60 "START MBR"
Example from a FIX32 script: Runtask c:\fix32\dctrl60 "START MBR"
8
iFIX_脚本进行调度的启动和关闭方法?
Description
This solution shows how to start and stop a time-based or event-based schedule running in the background.
Resolution
To Start:
Dim Var1 As Object
Dim Var2 As Object
Var2.StartEvent
End Sub
To Stop:
Dim Var1 As Object
Dim Var2 As Object
Var2.StopEvent
End Sub
Dim Var1 As Object
Dim Var2 As Object
End Sub
Dim Var1 As Object
Dim Var2 As Object
Var2.StartTimer
End Sub
9
iFIX_excel报表实现的方法?
注释: 1。该程序需要安装ADO 2.0目标库并在本机注册
' 2
Microsoft ActiveX Data Objects 2.1 Library 必须被引用 (Office 2000)
' 3
Microsoft Excel 9.0 object libraries 必须被引用 (Office 2000)
' 4
。划===处可根据具体报表修改
Dim strQueryAvg As String
Dim c As Integer
Dim r As Integer
Dim Intyexcel As Excel.Application
Dim MyDate, MyMonth, MyDay, MyHour, MyMinute, MySecond
Dim StartTime, EndTime, Duration, DisplayDay, DisplayMonth As String
报表中的 TAG
Dim Tag1, Tag2, Tag3, Tag4, Tag5, Tag6, Tag7, Tag8 As String
Dim Items As Integer
Tag1 = "TEST"
Tag2 = "TEST1"
Tag3 = " "
Tag4 = " "
Tag5 = " "
Tag6 = " "
Tag7 = " "
Tag8 = " "
从历史库中取得域项, 2 - DATATIME, VALUE, TAG 共三项
Items = 2
MyDate = Now()
MyMonth = Month(MyDate)
MyDay = Day(MyDate)
MyHour = Hour(MyDate)
MyMinute = Minute(MyDate)
MySecond = Second(MyDate)
StartTime = "2000" & "-" & MyMonth & "-" & MyDay - 1 & " " & "00:00:00"
EndTime = "2000" & "-" & MyMonth & "-" & MyDay - 1 & " " & "23:00:00"
查询,根据报表修改
strQueryAvg = "Select DATETIME, VALUE, TAG FROM FIX " & _
"WHERE MODE = 'AVERAGE' and (TAG='" & Tag1 & "' or TAG='" & Tag2 & "'" & _
" or TAG='" & Tag3 & "' or TAG='" & Tag4 & "' or TAG='" & Tag5 & "'" & _
" or TAG='" & Tag6 & "' or TAG='" & Tag7 & "' or TAG='" & Tag8 & "')" & _
"and INTERVAL = '01:00:00' and " & _
"(DATETIME >= {ts '" & StartTime & "'} and " & _
"DATETIME <= {ts '" & EndTime & "'})"
Dim cnADO As New ADODB.Connection
Dim rsADO As Recordset
Set cnADO = New ADODB.Connection
cnADO.ConnectionString = "DSN = FIX Dynamics Historical Data; UID = sa; PWD = ;"
cnADO.Open "FIX Dynamics Historical Data", "sa", ""
Set rsADO = New ADODB.Recordset
rsADO.Open strQueryAvg, cnADO, adOpenForwardOnly, adLockBatchOptimistic
如果执行上面的语句出错的话,则最大的可能性就是SQL语句有错误!
r = 1
Set Intyexcel = New Excel.Application
Intyexcel.Visible = False
打开的报表文件名
Dim OutReportFile As String
Dim InReportFile As String
InReportFile = "C:\Dynamics\App\HIST1"
Intyexcel.Workbooks.Open InReportFile & ".XLS"
Intyexcel.Sheets("Sheet2").Select
Intyexcel.Columns("A:Z").Select
Intyexcel.Selection.ClearContents
Intyexcel.Range("A1").Select
While rsADO.EOF <> True
With Intyexcel.Worksheets(2)
For c = 0 To Items
If rsADO(c) <> "" Then .Cells(r, c + 1).Value = rsADO(c)
Next c
r = r + 1
rsADO.MoveNext
End With
Wend
Intyexcel.Sheets("Sheet1").Select
' Intyexcel.ActiveSheet.PageSetup.Orientation = xlPortrait 'xlLandscape
' Intyexcel.ActiveSheet.PageSetup.PaperSize = xlPaperA4
Intyexcel.ActiveSheet.PrintOut
Intyexcel.DisplayAlerts = False
Intyexcel.ActiveWorkbook.Save
OutReportFile = InReportFile & "_00" & MyMonth & MyDay
Intyexcel.ActiveWorkbook.SaveAs OutReportFile
Intyexcel.Quit
Intyexcel.DisplayAlerts = True
Set Intyexcel = Nothing
Set cnADO = Nothing
End Sub
10
IFIX中对事件调度有没什么限制?
曾经用过用500个事件调度没事。
11
IFIX中求模拟量一段时间平均值?
Dim strvalue1 As Variant
Dim strvalue2 As Variant
Dim strvalue3 As Variant
Dim strvalue4 As Variant
Dim strvalue5 As Variant
Dim strvalue6 As Variant
Dim strvalue7 As Variant
Dim strvaluep As Variant
Private Sub FixTimer4_OnTimeOut(ByVal lTimerId As Long)
计算平均值
strvalue7 = strvalue6
strvalue6 = strvalue5
strvalue5 = strvalue4
strvalue4 = strvalue3
strvalue3 = strvalue2
strvalue2 = strvalue1
strvalue1 = Fix32.Fix.J001.a_cv
strvaluep = ((Val(strvalue1) + Val(strvalue2) + Val(strvalue3) + Val(strvalue4) +
Val(strvalue5) + Val(strvalue6) + Val(strvalue7)) / 7)
user.J001.CurrentValue = strvaluep
END SUB
12
:在IFIX中如何显示用户信息?
FIX32产品中,FIX内含一系列系统变量,存储当前系统信息,包括当前用户的注册信息,
#GS_LOGIN.NAME。在IFIX中可通过VBA代码,实现显示或获得用户的注册信息。代码如下:
Private Sub Text1_Click()
Dim sUserID As String
Dim sUserName As String
Dim sGroupName As String
System.FixGetUserInfo sUserID, sUserName, sGroupName
Text1.Caption = sUserName
aa761222aa | 2008-3-16 15:45:00 | 显示全部楼层
PLC技术网--就是好
ming7239 | 2008-3-31 15:07:00 | 显示全部楼层
不同版本的这些信息不同吧
forumtom | 2008-4-9 15:50:00 | 显示全部楼层
很好,经典制作
mo1728 | 2008-4-12 00:11:00 | 显示全部楼层
[em18][em20]
guanfeng | 2008-4-14 09:34:00 | 显示全部楼层
ifix4.0能用吗?
aixiaoyu | 2009-12-10 12:57:00 | 显示全部楼层
学习
