FlashFXP v3.5.3 build 1222 [3.6 RC3] Support Forums at http://forum.flashfxp.com Report a Bug at http://bugtracker.inicom.net WinSock 2.0 -- OpenSSL 0.9.8g 19 Oct 2007 [R] 正在连接到 ftp.plcjs.com -> DNS=ftp.plcjs.com IP=58.61.154.243 PORT=21 [R] 已连接到 ftp.plcjs.com [R] 220-BBSFTP Pro- [http://www.bbsftp.net/] [R] 220 Serv-U FTP Server v6.3 for WinSock ready... [R] USER plcjs_sinsin [R] 331 User name okay, need password. [R] PASS (hidden) [R] 230-(bbsftp v2.5) [Cache Update Disabled!] [R] 230 User logged in, proceed. [R] SYST [R] 215 UNIX Type: L8 [R] FEAT [R] 550 Command Not Support! [R] REST 100 [R] 350 Restarting at 100. Send STORE or RETRIEVE. [R] REST 0 [R] 350 Restarting at 0. Send STORE or RETRIEVE. [R] PWD [R] 257 \"/\" is current directory. [R] TYPE A [R] 200 Type set to A. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,19,250) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5114 [R] LIST -al [R] 150 Opening ASCII mode data connection for /bin/ls. [R] 226 Transfer complete. ( 可用下载流量: 20.889MB ) [R] 列表完成: 531 字节 用时 0.78 秒 (0.7 KB/s) [R] CWD 上传区 [R] 250 Directory changed to /上传区 [R] PWD [R] 257 \"/上传区\" is current directory. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,20,14) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5134 [R] LIST -al [R] 150 Opening ASCII mode data connection for /bin/ls. [R] 226 Transfer complete. ( 可用下载流量: 20.889MB ) [R] 列表完成: 12 KB 用时 2.31 秒 (5.4 KB/s) [R] CWD 工控播客视频 [R] 250 Directory changed to /上传区/工控播客视频 [R] PWD [R] 257 \"/上传区/工控播客视频\" is current directory. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,20,15) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5135 [R] LIST -al [R] 150 Opening ASCII mode data connection for /bin/ls. [R] 226 Transfer complete. ( 可用下载流量: 20.889MB ) [R] 列表完成: 241 字节 用时 0.69 秒 (0.3 KB/s) [R] MKD 视频教程 [R] 550 Access is denied. [R] PWD [R] 257 \"/上传区/工控播客视频\" is current directory. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,20,18) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5138 [R] LIST -al [R] 150 Opening ASCII mode data connection for /bin/ls. [R] 226 Transfer complete. ( 可用下载流量: 20.889MB ) [R] 列表完成: 241 字节 用时 9.66 秒 (0.0 KB/s) [R] CWD /上传区/建议上传 [R] 250 Directory changed to /上传区/建议上传 [R] PWD [R] 257 \"/上传区/建议上传\" is current directory. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,20,21) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5141 [R] LIST -al [R] 150 Opening ASCII mode data connection for /bin/ls. [R] 226 Transfer complete. ( 可用下载流量: 20.889MB ) [R] 列表完成: 176 字节 用时 0.69 秒 (0.3 KB/s) [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,20,30) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5150 [R] RETR 建议.txt [R] 550 Permission denied. [R] 传输失败! 传输队列已完成 1 个文件传输失败 [R] TYPE I [R] 200 Type set to I. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,20,20) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5140 [R] STOR a000003.3gp [R] 550 Access is denied. [R] 传输失败! [R] TYPE A [R] 200 Type set to A. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,20,32) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5152 [R] LIST -al [R] 150 Opening ASCII mode data connection for /bin/ls. [R] 226 Transfer complete. ( 可用下载流量: 20.889MB ) [R] 列表完成: 176 字节 用时 0.69 秒 (0.2 KB/s) 传输队列已完成 1 个文件传输失败 [R] TYPE I [R] 200 Type set to I. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,20,33) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5153 [R] STOR a000003.3gp [R] 550 Access is denied. [R] 传输失败! [R] TYPE A [R] 200 Type set to A. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,20,34) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5154 [R] LIST -al [R] 150 Opening ASCII mode data connection for /bin/ls. [R] 226 Transfer complete. ( 可用下载流量: 20.889MB ) [R] 列表完成: 176 字节 用时 0.80 秒 (0.2 KB/s) 传输队列已完成 1 个文件传输失败 [R] TYPE I [R] 200 Type set to I. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,20,35) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5155 [R] STOR a000003.3gp [R] 550 Access is denied. [R] 传输失败! [R] CWD /上传区 [R] 250 Directory changed to /上传区 [R] PWD [R] 257 \"/上传区\" is current directory. [R] TYPE A [R] 200 Type set to A. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,20,36) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5156 [R] LIST -al [R] 150 Opening ASCII mode data connection for /bin/ls. [R] 226 Transfer complete. ( 可用下载流量: 20.889MB ) [R] 列表完成: 12 KB 用时 0.91 秒 (13.7 KB/s) 传输队列已完成 1 个文件传输失败 [R] CWD PLC软件资料(视价值给流量) [R] 250 Directory changed to /上传区/PLC软件资料(视价值给流量) [R] PWD [R] 257 \"/上传区/PLC软件资料(视价值给流量)\" is current directory. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,19,252) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5116 [R] LIST -al [R] 150 Opening ASCII mode data connection for /bin/ls. [R] 226 Transfer complete. ( 可用下载流量: 20.889MB ) [R] 列表完成: 439 字节 用时 0.75 秒 (0.6 KB/s) [R] CWD /上传区/建议上传 [R] 250 Directory changed to /上传区/建议上传 [R] PWD [R] 257 \"/上传区/建议上传\" is current directory. [R] TYPE I [R] 200 Type set to I. [R] PASV [R] 227 Entering Passive Mode (58,61,154,243,20,37) [R] 正在打开数据连接 IP: 58.61.154.243 端口: 5157 [R] STOR a000003.3gp [R] 550 Access is denied. [R] 传输失败! [R] CWD /上传区/PLC软件资料(视价值给流量) [R] 250 Directory changed to /上传区/PLC软件资料(视价值给流量) [R] PWD [R] 257 \"/上传区/PLC软件资料(视价值给流量)\" is current directory. 传输队列已完成 1 个文件传输失败
