[电工&电子] 传动系统性能保证值(同步电机篇)
查看87853 | 回复0 | 2024-10-8 17:22:35 | 显示全部楼层 |阅读模式
概述
     相对于SINAMICS S120驱动异步交流电机,SINAMICS S120驱动同步电机的传动系统性能则能达到更高的静态和动态性能指标,因此,同步电机的传动系统性能保证值为大家提供了一个指标性评价依据,同时也提供了必要的测量条件和测量方法,满足以冶金行业中冷轧工艺为代表的要求非常严格的生产工艺。
1. 适用范围
(1)传动系统性能保证值的描述仅限于SINAMICS S120的矢量控制方式, 工艺对象为三相交流同步电动机。
(2)普遍适合输出较大轴功率的工业场合,比如轧机、试验台以及类似工况的生产线。
2.  性能保证值
       下面以传动系统性能要求较高的冷轧轧机为范本提出在测量条件、测量方法和条件下的保证值指标,并且提供相应的现场记录波形加以辅助说明。性能保证值条目如下:
    稳态速度精度
    速度阶跃响应时间及超调量
    调速范围
    力矩电流阶跃响应
    力矩电流控制精度
2.1 稳态速度精度
Static Speed accuracy for the uncoupled drive
Speed accuracy value less than ±0.01% for the uncoupled drive
Speed accuracy value less than  ±0.2% for the coupled drive
2.2速度阶跃响应时间及超调量
Speed step response time and overshoot
Speed response time is less than 50ms for the uncoupled drive
Speed response time is less than 100ms for the coupled drive
2.3调速范围Speed range
The system work normally at full speed for the uncoupled drive
The system work normally at full speed for the coupled drive
2.4力矩电流阶跃响应
Torque and current response
Current response time less than 6.5ms for the uncoupled drive
2.5 力矩电流控制精度
Torque and current control accuracy
Torque current accuracy value less than  ±1.0%  for the uncoupled drive
Torque current accuracy value less than  ±0.8% for the coupled drive
