Box rain test chamber
查看619 | 回复0 | 2011-6-2 14:34:00 | 显示全部楼层 |阅读模式
Purpose This product is applicable for the outer protection of exterior lighting, signal devices and car lamps(linpin). Chamber Structure The guiding upright column is made with high-quality channel steel welding and exterior splicing of stainless steel drawing blocks. A sample table with rotate speed adjustable is available. Control System Adjusts pressure with flowmeter(linpin). Adopts imported frequency converter to control rotate speed in order to ensure the test can be conducted as per the applied standards. A water filter is equipped. Standards Applied GB10485-89 GB4208-93 GB/T4942 Technical Requirements Model (cm) LX-500 LX-010 Workroom Dimensions 80*80*80 102*120*100 Exterior Dimensions 88*118*154 120*158*176 Power 2.0(KW) 2.5(KW) Water Spray Ring Radius 375mm 500mm Water Pipe Diameter φ16mm Spraying Hole Diameter φ0.4mm Aperture Spacing 50mm Swing Range ±45°,±60°,±90°,±180° Test Bench Rotation Speed 1r/min, or stepless speed regulating (optional)
