<g data-mml-node="mo"><text data-variant="normal" transform="matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">一</text><text data-variant="normal" transform="translate(946.9, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">下</text><text data-variant="normal" transform="translate(1893.7, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">太</text><text data-variant="normal" transform="translate(2840.6, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">累</text><text data-variant="normal" transform="translate(3787.4, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">了</text><text data-variant="normal" transform="translate(4734.3, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">,</text><text data-variant="normal" transform="translate(5681.2, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">没</text><text data-variant="normal" transform="translate(6628, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">关</text><text data-variant="normal" transform="translate(7574.9, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">系</text><text data-variant="normal" transform="translate(8521.7, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">,</text><text data-variant="normal" transform="translate(9468.6, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">你</text><text data-variant="normal" transform="translate(10415.5, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">可</text><text data-variant="normal" transform="translate(11362.3, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">以</text><text data-variant="normal" transform="translate(12309.2, 0) matrix(1 0 0 -1 0 0)" font-size="947.1px" font-family="serif">把</text></g>? 放在提示符里去:
3. 将上次命令执行是否成功的返回值放到提示符里面去:export PS1="[\$?]${PS1}"
root@ubuntu:/home/peng/zhh# export PS1="[\$?]${PS1}"[0]root@ubuntu:/home/peng/zhh# lsexport PS1="[\$?]${PS1}" 这个命令把 $? 的值放在的提示符的最前面,这样每次执行完命令,这个值都会自动更新,这下就一目了然了~
4. 用perror查看错误提示
那么如果返回的值不是 0,我们要怎么知道是那里出错了呢?大多数的程序出错都会给出提示,如果没有提示的话,可以用 perror 这个程序来查看错误的信息,比如返回值是 2,我们可以运行下面命令:
$ perror 2OS error code 2: No such file or directory这样就清楚了,原来是文件不存在~
该命令需要安装apt-get install perror
5. 给出错误代码及其具体原因对照表:
"OS error code 1: Operation not permitted""OS error code 2: No such file or directory""OS error code 3: No such process""OS error code 4: Interrupted system call""OS error code 5: Input/output error""OS error code 6: No such device or address""OS error code 7: Argument list too long""OS error code 8: Exec format error""OS error code 9: Bad file descriptor""OS error code 10: No child processes""OS error code 11: Resource temporarily unavailable""OS error code 12: Cannot allocate memory""OS error code 13: Permission denied""OS error code 14: Bad address""OS error code 15: Block device required""OS error code 16: Device or resource busy""OS error code 17: File exists""OS error code 18: Invalid cross-device link""OS error code 19: No such device""OS error code 20: Not a directory""OS error code 21: Is a directory""OS error code 22: Invalid argument""OS error code 23: Too many open files in system""OS error code 24: Too many open files""OS error code 25: Inappropriate ioctl for device""OS error code 26: Text file busy""OS error code 27: File too large""OS error code 28: No space left on device""OS error code 29: Illegal seek""OS error code 30: Read-only file system""OS error code 31: Too many links""OS error code 32: Broken pipe""OS error code 33: Numerical argument out of domain""OS error code 34: Numerical result out of range""OS error code 35: Resource deadlock avoided""OS error code 36: File name too long""OS error code 37: No locks available""OS error code 38: Function not implemented""OS error code 39: Directory not empty""OS error code 40: Too many levels of symbolic links""OS error code 42: No message of desired type""OS error code 43: Identifier removed""OS error code 44: Channel number out of range""OS error code 45: Level 2 not synchronized""OS error code 46: Level 3 halted""OS error code 47: Level 3 reset""OS error code 48: Link number out of range""OS error code 49: Protocol driver not attached""OS error code 50: No CSI structure available""OS error code 51: Level 2 halted""OS error code 52: Invalid exchange""OS error code 53: Invalid request descriptor""OS error code 54: Exchange full""OS error code 55: No anode""OS error code 56: Invalid request code""OS error code 57: Invalid slot""OS error code 59: Bad font file format""OS error code 60: Device not a stream""OS error code 61: No data available""OS error code 62: Timer expired""OS error code 63: Out of streams resources""OS error code 64: Machine is not on the network""OS error code 65: Package not installed""OS error code 66: Object is remote""OS error code 67: Link has been severed""OS error code 68: Advertise error""OS error code 69: Srmount error""OS error code 70: Communication error on send""OS error code 71: Protocol error""OS error code 72: Multihop attempted""OS error code 73: RFS specific error""OS error code 74: Bad message""OS error code 75: Value too large for defined data type""OS error code 76: Name not unique on network""OS error code 77: File descriptor in bad state""OS error code 78: Remote address changed""OS error code 79: Can not access a needed shared library""OS error code 80: Accessing a corrupted shared library""OS error code 81: .lib section in a.out corrupted""OS error code 82: Attempting to link in too many shared libraries""OS error code 83: Cannot exec a shared library directly""OS error code 84: Invalid or incomplete multibyte or wide character""OS error code 85: Interrupted system call should be restarted""OS error code 86: Streams pipe error""OS error code 87: Too many users""OS error code 88: Socket operation on non-socket""OS error code 89: Destination address required""OS error code 90: Message too long""OS error code 91: Protocol wrong type for socket""OS error code 92: Protocol not available""OS error code 93: Protocol not supported""OS error code 94: Socket type not supported""OS error code 95: Operation not supported""OS error code 96: Protocol family not supported""OS error code 97: Address family not supported by protocol""OS error code 98: Address already in use""OS error code 99: Cannot assign requested address""OS error code 100: Network is down""OS error code 101: Network is unreachable""OS error code 102: Network dropped connection on reset""OS error code 103: Software caused connection abort""OS error code 104: Connection reset by peer""OS error code 105: No buffer space available""OS error code 106: Transport endpoint is already connected""OS error code 107: Transport endpoint is not connected""OS error code 108: Cannot send after transport endpoint shutdown""OS error code 109: Too many references: cannot splice""OS error code 110: Connection timed out""OS error code 111: Connection refused""OS error code 112: Host is down""OS error code 113: No route to host""OS error code 114: Operation already in progress""OS error code 115: Operation now in progress""OS error code 116: Stale NFS file handle""OS error code 117: Structure needs cleaning""OS error code 118: Not a XENIX named type file""OS error code 119: No XENIX semaphores available""OS error code 120: Is a named type file""OS error code 121: Remote I/O error""OS error code 122: Disk quota exceeded""OS error code 123: No medium found""OS error code 124: Wrong medium type""OS error code 125: Operation canceled""OS error code 126: Required key not available""OS error code 127: Key has expired""OS error code 128: Key has been revoked""OS error code 129: Key was rejected by service""OS error code 130: Owner died""OS error code 131: State not recoverable""MySQL error code 132: Old database file""MySQL error code 133: No record read before update""MySQL error code 134: Record was already deleted (or record file crashed)""MySQL error code 135: No more room in record file""MySQL error code 136: No more room in index file""MySQL error code 137: No more records (read after end of file)""MySQL error code 138: Unsupported extension used for table""MySQL error code 139: Too big row""MySQL error code 140: Wrong create options""MySQL error code 141: Duplicate unique key or constraint on write or update""MySQL error code 142: Unknown character set used""MySQL error code 143: Conflicting table definitions in sub-tables of MERGE table""MySQL error code 144: Table is crashed and last repair failed""MySQL error code 145: Table was marked as crashed and should be repaired""MySQL error code 146: Lock timed out; Retry transaction""MySQL error code 147: Lock table is full; Restart program with a larger locktable""MySQL error code 148: Updates are not allowed under a read only transactions""MySQL error code 149: Lock deadlock; Retry transaction""MySQL error code 150: Foreign key constraint is incorrectly formed""MySQL error code 151: Cannot add a child row""MySQL error code 152: Cannot delete a parent row" -----END-----
关注,回复【1024】海量Linux资料赠送
精彩文章合集
点击“阅读原文”查看更多分享,欢迎点分享、收藏、点赞、在看
