WD-Card is a Smart Universal PCI Multiport Serial Board designed for POS and ATM applications, and for use by industrial automation system manufacturers and system integrators. WD-Card is compatible with all popular operating systems, and each of its 2/4/8/16 RS-232 serial ports supports data rates of up to 921.6 Kbps, and provides full modem control signals, ensuring compatibility with a wide range of serial peripherals. In addition,WD-Card works with both 3.3V and 5V PCI buses, allowing the board to be installed in virtually any available PC server. WD系列聪明型PCI总线串口多用户卡适用于POS、ATM、工业自动控制等应用。本系列多用户卡支持绝大多数操作系统,它的每个端口支持高达921.6Kbps的速度,同时每个端口均为标准全信号RS232端口,提供调制解调器的所有控制信号,并于大多数串口设备兼容。 WD系列聪明型PCI总线串口多用户卡可工作在3.3V和5V PCI总线环境中,可被安装在所有的PC机、工控机中。 Over 800 Kbps data throughput, top performance in the world Serial communication speed up to 921.6 Kbps 128-byte FIFO and on-chip H/W, S/W flow control Universal PCI compatible, with 3.3/5V PCI and PCI-X Low profile board for compact-sized PC Windows 2003/XP/2000/98/ME, Linux, UNIX driver support Single 5 VDC power requirement On-board 15 KV ESD protection Bus(总线): 32-bit, Universal PCI Serial(接口): RS-232 No. of Ports(口数): 2/4/8/16 Signals(信号): TxD, RxD, RTS, CTS, DTR, DSR, DCD, GND Speed(速度): 50 bps to 921.6 Kbps Parity(校验): None, even, odd, space, mark Data Bits(数据位): 5, 6, 7, 8 Stop Bits(停止位): 1, 1.5, 2 Flow Control(流量控制):RTS/CTS, XON/XOFF IRQ, I/O Address(中断和I/O地址): Assigned by BIOS Operating Systems(操作系统): Windows NT/2000/XP/2003, Windows 95/98/ME, Linux 2.6/2.4(Red Hat, SuSe, etc.), FreeBSD, SCO OpecServer,SCO Unixware 7,SCO Unixware 2.1, Embedded Windows XP, QNX, DOS Power Requirements(电源):120 mA (+5V) Operating Temperature(工作温度): 0 to 55°C Operating Humidity(工作湿度):5 to 95% RH Storage Temperature(存储温度):-20 to 85°C
